Couple quick questions, help please.
Old Mar 1, 2007 | 04:24 PM
Lucky-13's Avatar
Default Couple quick questions, help please.
Alright I am in the process of putting my car together. I have a couple questions if anyone may know the answer??
1. I have a radiator fan with wiring still connected, where exactly does the wiring go?? I have a switch in my car but I dont know what to do to get it all working. For instance would I put the p wire to the switch and then just ground it by the fan itself??
2. Also I dont have any seat bolts, I need 8 bolts to mount the brackets in my car, does anyone know the size??
Old Mar 1, 2007 | 05:20 PM
Lucky-13's Avatar
Default Re: Couple quick questions, help please. (YouvGotMail)
by the wiring with the fan I mean I have a foot long wire connected to the the fan itself, then one wire coming from the switch to the engine bay. Do i just put the switch wire on the fan and ground the fan?? Or do I have to ground the switch part too??
Old Mar 1, 2007 | 05:41 PM
EL Vap133's Avatar
Bolts for the seat are 12mm.
Old Mar 2, 2007 | 11:41 AM
Lucky-13's Avatar
Old Mar 2, 2007 | 04:00 PM
jdm-lab's Avatar
you need to have the postive wire hooked up to your battery or some kind of power. then you to ground the other wire any where on the chasis
Old Mar 2, 2007 | 04:04 PM
jdm-lab's Avatar
Default Re: Couple quick questions, help please. (jdm-lab)
sorry brain fart . but you need a ground to the chasis, then you need power to the switch which you run one wire from your battery to the switch. then you need another wire from the switch it's self to the fan. hope that helps
Old Mar 2, 2007 | 04:47 PM
Lucky-13's Avatar
Yes that definitly helped. Lol thanks alot
Dee9222
Mar 18, 2014 01:34 AM
Eg.ls.turbo
12
Nov 27, 2013 10:34 AM
ever'sneighborhood
Mar 26, 2009 07:46 PM
4DRmafia
10
Jun 20, 2004 10:49 PM
st0nedstoopid
Jul 11, 2003 12:19 AM
