z6 head on a y7 block...
Old Mar 1, 2007 | 04:12 PM
purple98ek's Avatar
Default z6 head on a y7 block...
What timing belt do i use?......distributor?........i know to use a y8 headgasket........anything else i should get?......thanks
Old Mar 1, 2007 | 04:35 PM
quadnie's Avatar
Default Re: z6 head on a y7 block... (purple98ek)
The y7 and y8 blocks are prone to oil pump failure. You need to swap out an oil pan and oil pump from a d16a6 or d16z6
Old Mar 1, 2007 | 05:58 PM
purple98ek's Avatar
Default Re: z6 head on a y7 block... (quadnie)
thats news to me........anyone who isn't an h-t virgin care to remark?
Old Mar 1, 2007 | 06:02 PM
92hatch_cx-t's Avatar
i think this will answer everythin
https://honda-tech.com/zerothread?id=554053
good luck!!!!!!
Old Mar 1, 2007 | 06:07 PM
purple98ek's Avatar
Default Re: (sohc dis)
thanks.....i have seen this writeup but it doesnt give the exact parts needed for a z6 head on a y7 block.......i am pretty sure i need to use the z6 belt and distributor, but am just making sure
Old Mar 7, 2007 | 02:02 PM
purple98ek's Avatar
Default Re: (purple98ek)
also, does anyone know if i can use the z6 throttle body?
Old Mar 7, 2007 | 02:07 PM
knockout's Avatar
Well what intake manifold are you using?
Old Mar 7, 2007 | 02:08 PM
purple98ek's Avatar
Default Re: (knockout)
i will be using the z6 manifold......
Old Mar 7, 2007 | 02:14 PM
knockout's Avatar
Then I dont see why you couldnt run a z6 throttle body, it should be fine since youre using the matching intake manifold.
Old Mar 7, 2007 | 02:17 PM
purple98ek's Avatar
I was just wondering about the various sensors that are different than my y7 throttle body.......do you know of any write ups on putting a z6 head on a y7 block?........I searched but i couldn't find a specific write up........
Old Mar 7, 2007 | 02:22 PM
knockout's Avatar
Not really, because most people that have y7's do a y7/y8 minime. I'm not sure why they just do...sorry I couldnt help.
Old Mar 7, 2007 | 02:28 PM
purple98ek's Avatar
yeah, i know......i cant really find any write ups on a z6/y7 mini me.......it is all y8/y7...........i guess i will have to give it the old college try
Old Mar 8, 2007 | 02:57 PM
purple98ek's Avatar
now, what about injectors.......can i use y8 injectors since they are obd2 like my car?..........
Old Mar 8, 2007 | 03:08 PM
seabass10369's Avatar
as far as tb and injectors if u use stock y7 ecu u gotta use the y7 tb and injectors, timing belt its the same for y8 and z6 and y7, now as long as u use the z6 cam gear on the head setting valve timing should be the same as normal, but from what i know z6 ig nition timing is 12 degrees y8/7 are 16 degrees i think i have not gotten a look at parts to confirm this myself. maybe someone else can tell you more on inginiton timing
and typically u should use the distributor that matches the head, in this case z6 just swith the wiring to work with 0bd2 harness thats just the rule of thumb ive heard a y7 distrib might work
Old Mar 8, 2007 | 04:26 PM
purple98ek's Avatar
Default Re: (seabass10369)
thanks for the input.........i have the z6 dizzy and thats what i will be using.........i just dont think that y7 injectors provide enough fuel.........so my question stands: should i use y8 injectors?........can i use the y8 injectors on my y7 fuel rail?.....
Old Mar 8, 2007 | 04:38 PM
knockout's Avatar
if youre going to use the y8 intake manifold, use its corresponding parts (fuel rail, injectors, TB) because it will just make it that much easier for you.
Old Mar 8, 2007 | 05:40 PM
purple98ek's Avatar
well, i am going to use the z6 manifold.......but the z6 injectors are obd1 and my car is obd2 and i dont want to cut my harness to use the injectors.......that is why i wanted to know if y8 injectors........i dont know.......i wish there was a z6/y7 write up
Old Mar 8, 2007 | 08:42 PM
after i thought about it i realized u have to change the ecu the only reason i was saying before to use y7 injectors was if you used a y7 ecu but when i stopped and thunk i realize that wouldnt work your going for vtec, and with a y8 ecu with is what i assume you will use you will need a knock sensor
Old Mar 8, 2007 | 09:00 PM
purple98ek's Avatar
well, that is one of the questions i have..........if i wire the vtec solenoid to run off a msd activated switch then i could keep my ecu, but will the y8 injectors function ok with a y7 ecu?
Old Mar 9, 2007 | 06:20 AM
no y8 injectors will not work on y7 ecu it will run too rich
dsnONE
Apr 13, 2010 04:12 PM
foam
Nov 15, 2006 01:06 PM
AlizeVS
Nov 29, 2004 04:14 PM
spun Vtec
Jan 31, 2003 08:42 AM
