Seat belt problem. Inertia reels don't lock?
Old Mar 1, 2007 | 02:30 PM
JV's Avatar
JV
Who?
Default Seat belt problem. Inertia reels don't lock?
I recently purchased a 1991 Civic DX to use as a daily, and i just noticed that the inertia reels do not lock up when i tug on the front belts... Not too safe.
Anyway,
I did some searching on here and came across this thread:
https://honda-tech.com/zerothread?id=1895711
And this post is what interested me the most:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Take it to the dealer. Yes, you heard me, take it to the dealer. Lifetime Warranty FTMFW!</TD></TR></TABLE>
Is this true? Will they replace them free of charge or will they try and rake me over the coals with labor fees and such?
Old Mar 1, 2007 | 02:47 PM
goforbroke's Avatar
MEAT PATTY
Default Re: Seat belt problem. Inertia reels don't lock? (JV)
You can take it too the dealer. Its covered under warranty, mine were busted also. I just went to the junkyard and pickedup ones that worked. My hatch is too busted to take it to the dealer.
Old Mar 1, 2007 | 02:50 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> When you take it to the dealer, they should tell you this -
"Is covered under warranty if the car hasn't been crashed"
And then the scare tactic
"If it isn't the seatbelt system you will be charged an 80$ service fee"
Old Mar 1, 2007 | 04:36 PM
They'll check the VIN of course, and the normal check for any obvious signs of crash damage (frame, doors, etc).
Old Mar 2, 2007 | 12:43 PM
import2nr88's Avatar
They will change them out, The service guy told me that they will change them free of charge as long as they are not inoperable because of trash or crap and that its a mechanical failure. I asked what if they are and he said once they get that far they usually change them any ways because the dealer makes more by warrentying them then they would charging you the one hour labor. i had both of mine changed and only one was not working correctly
Old Mar 2, 2007 | 04:58 PM
ChickenH's Avatar
I work at one and they said : IF its not abused, modified its lifetime warranty.
Old Mar 2, 2007 | 05:01 PM
user 25438239's Avatar
edit: never mind. i know what you mean.
Old Mar 2, 2007 | 05:39 PM
PACT man's Avatar
Default Re: (JCrimson)
The dealership will do this as long as the part is still available(they stop producing parts for the car after 10 or 15 years, dont remember which one; example: at Acura, you can still get black but not blue seatbelts for a DA). Its a safety lifetime warranty.
But, is it just me or was he asking about locking up the seat belt, which is that case, Honda seat belts only lock up under hard braking. There is a little pendlum(sp?) thing inside the device then when braking hard(as if trying to avoid an accident) swings forward and locks the seat belt. So go find an empty road and get going and briskly hit the brakes and that should tell you if they are really working properly. If not then go to the dealership.
I got seatbelts for my DA at the junkyard not too long ago also and they work good too.
Old Mar 2, 2007 | 05:45 PM
grog's Avatar
mine work on the road when braking, and not when I tug on them,
anybody else.
I wonder if tugging on them (for this car) is the way to check them?
I know the door mounted seatbelts dont retract
Old Mar 2, 2007 | 06:31 PM
PACT man's Avatar
Default Re: (JV)
While I know my DA works with the pendulum, and they are the same manufacturing generation.
Old Mar 3, 2007 | 11:41 AM
Fred n J_v2.0's Avatar
Default Re: (JV)
eh, who needs seat belts???
Old Mar 4, 2007 | 06:01 PM
alphajesse's Avatar
Ever since I put a h22 in my ef, I manage to lock the belts under acceleration all the time. :D
PhantoM.DA
Apr 29, 2008 02:12 PM
Demonis
Dec 19, 2007 12:02 PM
nihkon
15
Feb 13, 2007 04:07 PM
fkguitar
14
May 24, 2005 01:11 AM
silverEH2
13
Mar 26, 2003 08:27 AM
