camber kit needed for front???
Old Mar 1, 2007 | 01:42 PM
lilpastrana's Avatar
Default camber kit needed for front???
i got a 1990 honda civic that had winter tires on it and came with 17s in the back so i was looking at the tires and both front tires had really bad inside wear so i was think that i might need a camber kit and i dont want to throw on nice tires if there is going to be bad wear and the winter tires have some wear but not wires showing so please help with this problem if i just need an alliment or a camber kit or both thank you.
Old Mar 9, 2007 | 05:29 PM
Default Re: camber kit needed for front??? (lilpastrana)
BUmp... tires are wearing away
Old Mar 9, 2007 | 05:34 PM
garageEF's Avatar
some people will argue that a good alignment is enough. i dont think this is true, ive had alot of camber problems. get a camber kit for the front and use washers and longer bolts to adjust the rear. camber kits are a bitch to put in but its the only sure way to fix the problem.
Old Mar 9, 2007 | 06:07 PM
gospeedgo1's Avatar
Default Re: camber kit needed for front??? (garageEF)
get the adjustable UCAs so you dont hit your fender all crazy like with the adjustable ball joints.
PiZZaBoY7000
Dec 8, 2011 04:05 PM
91EF919
15
Jun 24, 2009 07:15 AM
super jdm yo
Sep 7, 2006 08:41 PM
bigheadedhatch91
Mar 2, 2005 03:48 PM
InfamousRS
Feb 14, 2002 07:31 AM
