95' Integra 2 door GSR front suspension VS. 94' LS SEDAN front suspension
I was driving in the snow with my 95' gsr and i slipped on black ice in a curve. MY wheel hit the curb and was shifted back to the plastic lining literally. i was wondering if i could swap the front suspension of my four door ls sedan into my gsr. And if its possible if anyone knows, to know what part of the suspension is most likely to bend to cause my wheel to shift back so much. Ill send a pic if you guys like. Thanks.
## By the way i have a 94' integra sedan available to part out" tan leather seats fair condition except drivers seat. tailights, windows, doors, miscellaneous.
its also possible the subframe is bent. be sure to compare the one on your gsr to the subframe on the sedan, they are interchangable, but dont bother changing parts unless you have to.
make sure you get an alignment afterwards also
Ill try to get some pics later on of the bent parts compared to the good ones. And thanks for the replies. One last question though, what exactly is the subframe? Is it the black piece where the control arm hooks up to and is bolted to the chassis?
I was also thinking that the forks, shock and other pieces have the busihngs and that might give way so the bent part might vary between the subframe and the control arm....Just a thought.
