ITR cluster in GSR?
Old Mar 1, 2007 | 01:12 PM
blkackteg's Avatar
Default ITR cluster in GSR?
I just did a b18c5 swap and want to put in the itr cluster. the cluster is from an 01 itr so its odb2 and my teg is odb1. I plugged it in and the gages were nutty- my turn signal caused my tach to move. How can I get this working? thanks.
Old Mar 1, 2007 | 01:23 PM
Solscud007's Avatar
Default Re: ITR cluster in GSR? (blkackteg)
there has been a lot of thread on this topic. Basically you need to change the green film from your stock gauges. I hear that works.
Old Mar 1, 2007 | 01:45 PM
ItRsPoOn8's Avatar
Default Re: ITR cluster in GSR? (Solscud007)
yes i had the same problem, but i have a nother issue my type r gauge cluster, it not that bright at night time, i have adjust the dimmer but it does not work, can some one help me out, or give me advise how to fix the problem
Old Mar 1, 2007 | 01:46 PM
Jimmy's Avatar
Global Moderator
Maybe this will help, if not search.. it's been covered..
https://honda-tech.com/zerothread?id=1836281
Canon Chhoun
Jan 22, 2019 06:51 PM
B16smku
Apr 1, 2008 07:23 PM
Downz
Jul 9, 2007 11:21 AM
GuitarSlinger78
Nov 14, 2006 10:56 AM
:jdmshmaydm:
Apr 29, 2003 04:13 AM
