00 civic cat conv ?s
my civic stopped running was making a bunch of noise, sounded like my timing belt , had that done now its not running and i was thinking my cat is clogged, my o2 sensor needs to be done and its was running rich after i had it scanned, i ordered the 02 but it wont be in til monday, when cranking it over i felt no pressure coming out of exhaust pipe
any ideas or help
also wanted to know if i bought this cat conv of ebay if i would have probs w it passing emissions in NY?
http://cgi.ebay.com/ebaymotors...wItem
any ideas or help
you honestly think you'll be getting a real catalytic converter for 10 bucks? Newsflash, real cats from the dealership can cost upwards of a grand, if you bid on that, you're getting an empty pipe, gauranteed NOT to pass emissions. What you need to do is find an OEM honda cat, either here on HT or at a junkyard or something, install it and you'll be fine. You could even get an aftermaket such as a magnaflow cat. I've worked with them, they make a good affordable product (50-250 bucks). If you take a generic size to a muffler shop they can weld it in, and then weld your secondary o2 sensor downstream of the cat and it should be fine.
EJeff8
18
Aug 20, 2010 11:47 AM
redciviclx14
10
Jul 8, 2003 07:39 PM
