head unit wiring problem in a 95 civic sedan
Old Mar 1, 2007 | 10:13 AM
Projekt_2nr's Avatar
Default head unit wiring problem in a 95 civic sedan
i just installed my 2006 alpine cda-9857 head unit into my civic and it will not tunr on, there is a red with black stripe wire from the civic's harness that was left over, does anyone know what this wire might be? and what may be the problem? all fuses are good and the unit is brand new
Old Mar 1, 2007 | 10:18 AM
Default Re: head unit wiring problem in a 95 civic sedan (Projekt_2nr)
bump
Old Mar 1, 2007 | 10:25 AM
someone help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 1, 2007 | 10:30 AM
pdiggitydogg's Avatar
you wrote this 15 mins ago...chill the expletive out...
http://www.installdr.com/Harnesses/HA-Wiring.pdf
Old Mar 1, 2007 | 10:32 AM
Default Re: (pdiggitydogg)
i used the installdr.com site wiring diagram, no where on it does it say what the red with black stripe wire is meng
Old Mar 1, 2007 | 10:35 AM
red/black is for dimmer (at least usually)
it certainly isnt going to solve your problem
you either have it wired incorrectly or you have a fuse blown (despite what you say)
Old Mar 1, 2007 | 10:37 AM
wtf g, i wired everything correctly, i had this problem once b4 with a different head unit.
Old Mar 1, 2007 | 10:56 AM
19992civichatch's Avatar
what was the problem last time
Old Mar 1, 2007 | 11:08 AM
choppedndropped's Avatar
Default Re: (19992civichatch)
Get a tester and hook it up to the wires each one individually, turn the key on and off and to accessory and make sure you have the wires right, check your fuses, relays, and see if you have any wires that are pinched and are grounding prematurely. I just typed the same thing in another post for some other dude w/ the same prob...u guys need to check out other posts...
Old Mar 1, 2007 | 12:33 PM
Default Re: (choppedndropped)
the ***** gay, if i put the factory unit back in it works, but when ever i install a head unit according to the diagrams, they wont power up,the fuses are good, all the wires are correct so idk if it's just the unit, i think i'll just take it back and see if i can get a different one
Old Mar 1, 2007 | 03:07 PM
wire the headunit right off the battery to see if it works at all
seky478
Audio / Security / Video
Jun 20, 2017 02:21 AM
iJDMBB6
Mar 17, 2009 05:57 PM
j0keefe21
Jan 6, 2009 04:05 PM
Ruskimafia
May 12, 2006 11:09 AM
SleepnCiViC
Nov 10, 2003 07:11 AM
