I know this isnt the place for this topic but they won't let me post on the Misc Help Section
They wouldn't let me post in the Misc and Appearance section. I just took out my CD Player and tried putting a new one in. The new one does not power up, I checked the fuses and rewired everything but still no power. Can anyone help?
im having the same probl;em were you left with an extra red with black stripew wire from the civic's harness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Projekt_2nr »</TD></TR><TR><TD CLASS="quote">im having the same probl;em were you left with an extra red with black stripew wire from the civic's harness?</TD></TR></TABLE>
no im only left with the orange illumination dash light wire
Get a tester light and check your power wires, turn the key on and off to see which are you constant power, accessory power and so on. If the wires aren't getting power it could be a fuse you over looked, a pinched wire thats being grounded somewhere, or bad relays...
im still having this problem, i tried to check the relays but don't know what to look at for a bad relay
in the under hood fuse block there is a fuse marked "BACK-UP" it is a 7.5A fuse...hondas generally will not operate an aftermarket CD player without that fuse even though the stock one will still work without it...mine was completely missing and i couldnt figure out why my new cd player wouldnt work a few years ago but i threw a 15A fuse in there and it's been fine ever since, i also fixed a friends at school like this. good luck
