Car won't start after it's warmed up
Alright, problem with my girlfriend's 88 CRX Si. The car starts perfectly fine first thing in the morning or if it's been sitting for a while, but if you drive it for a bit, turn it off (like to get gas at a gas station) it just turns over won't start after.
It used to have a "hunting" irratic idle where it would bounce from 1000-1800~ rpm but I fixed that last night by cleaning the IACV with some carb cleaner. A couple times the check engine light has come on while driving, but it only stays on for a few seconds then goes off. I checked the ECU and it was a code 7 - TPS sensor. Could this be the source of the problem?
Also, when the car won't start, if I prime it a few times (put the key in accessory mode for a few seconds, then turn the key back to off, then repeat a few times) it will usually start right up. That to me sounds more like fuel pump or main relay... Is the TPS code just a coincidence?
Please help!
Please help!
probably main relay...go to the junkyard and pocket it or find one on here...parts supplier cheapest i found was 40 dollars
the main relay are the same for the ef/ed's I even think the eg are the same but not positive. I had a The same problem with my integra, I changed the ignitor and the relay at the same time and it never did it again.
Fix it yourself. Save a trip, tiem and $$
http://techauto.tripod.com/mainrelay.htm
His instructions say to remove old solder. This is the right way to do it. I just add solder, worked fine for me.
lukehonda
Aug 4, 2011 03:36 PM
yusoslo
Sep 28, 2003 12:29 PM
