"H" center cap research
Ok So I recently bought LS Meshes as winter wheels for $175 and traded my friend, dyingwish, for his Fat 5s.
From this
To this
I compared the LS Mesh "A" logo center cap and they are shorter than the fat 5 "acura" logo center caps.
So If you put an "acura" center cap into an LS mesh it will stick out about a 1/8".
I have been researching "H" centercaps for my Fat 5s. and i refuse to pay the ridiculous prices of 20-25 dollars per center cap for the 99-00 SI caps.
I have found some interesting and affordable solutions.
This I believe will fit a LS Mesh perfectly. I will check with my friend and test it on his car later today.
Here it is on my spare fat 5.
44732-S5P-A01
And how much does this center cap cost? why only $8 at the honda dealership. Now that is much better than $20-25
As you can see it is not flush. You could try to push it out a bit to be flush but i would not recommend it. as the plastic clips would not be seated on the ridge that holds it in place.
here is a comparison with a true "acura" fat 5 center cap
Here are some other OEM honda wheels that are optional. I need to track down these center caps and compare the height.
Oh here is the center cap for the Fit HFP wheels
From this
To this
44732-S5P-A01
IGotNoSwap
Sep 27, 2005 06:05 PM
