searched and searched but still have mini-me questions with a y8 head
im tired of reading and seeing all sorts of different info on this swap. there is a realy nice step by step swap using a Z6 head i found in the FAQ section http://crx.honda-perf.org/arti....html so are the steps the same except use all y8 parts? ALSO im buying head studs do i need to get them for the A6 or the Y8???? dont throw the SEARCH answer at me because i have all i want is a simple and solid answer so i dont waste my money on parts i dont need.
You need to use parts that will match the head you are using, which in this case is the Y8. So head studs, timing belt, head gasket should all be Y8 parts. Also, don't forget to pull the oil jet in the block. Good luck with the build.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nate@KAIZENSPEED »</TD></TR><TR><TD CLASS="quote">SOHC....WEAK! I say dohc swap and crv drivetrain!</TD></TR></TABLE>
wtf is the point in posting that^^^?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator88 »</TD></TR><TR><TD CLASS="quote">
haha dont mind nate hes a dumb friend of mine just talking ****
</TD></TR></TABLE>haha dont mind nate hes a dumb friend of mine just talking ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">You need to use parts that will match the head you are using, which in this case is the Y8. So head studs, timing belt, head gasket should all be Y8 parts. Also, don't forget to pull the oil jet in the block. Good luck with the build.</TD></TR></TABLE>
wrong.
For a6 with y8 head you need:
d15b7 timing belt
d16a6/z6 head studs (with one cutom stud by vtec solenoid..you can special order from ARP)
y8 headgasket
wrong.
d15b7 timing belt
y8 headgasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nate@KAIZENSPEED »</TD></TR><TR><TD CLASS="quote">The point is that we always talked about Matt putting his built b series in there with crv drivetrain, it was a inside joke. I guess you thought that I was really calling it weak.
sorry man. i checked out ur website then. pretty cool stuff
my apologies!!
</TD></TR></TABLE>sorry man. i checked out ur website then. pretty cool stuff
my apologies!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard »</TD></TR><TR><TD CLASS="quote">
wrong.
d15b7 timing belt
y8 headgasket
I have a y8 timing belt, a6 head studs, and y8 head gasket on my car a6/y8 setup. Meh, it works. More than 1 way to skin a cat. Everyone here will tell you that won't work though of course.
wrong.
d15b7 timing belt
y8 headgasket
keepinitsimple
Feb 17, 2005 11:32 AM
scratchy
Oct 10, 2003 01:52 PM
