Fried a power wire, can I tap into a near by wire?
Old May 21, 2002 | 04:50 PM
OR-G's Avatar
Default Fried a power wire, can I tap into a near by wire?
I was installing a new HU, and accidently touched the constant power wire to a piece of metal, it made a small spark, and now I don't get any power out of that wire. I checked all my fuses and none of them are burned. Is there a constant power wire I can tap into to power my HU?
This is on a 94 Civic Hatch.
Old May 21, 2002 | 05:03 PM
Kamin's Avatar
Default Re: Fried a power wire, can I tap into a near by wire? (OR-G)
you popped a fuse man
if you HAVE TO the best way is to just run a new wire from the battery. make SURE you put a fuse in it. i had to run a power wire (still have no idea whats wrong, also my clock is jacked)
Old May 21, 2002 | 05:10 PM
OR-G's Avatar
Default Re: Fried a power wire, can I tap into a near by wire? (KAMiN)
I checked all my fuses, and they are fine. Is there any other wire I can tap into?
Old May 21, 2002 | 05:31 PM
Kamin's Avatar
i wouldnt
you need a constant 12v source for the deck.
go from the battery. its not difficult
Old May 22, 2002 | 04:51 AM
Mista Bone's Avatar
D Tranny Guru
well, I don't think you check ALL the fuses. One is blown somewhere.
Old May 22, 2002 | 06:12 AM
TurboBumblBee's Avatar
check the fuses under the hood
you probably blew the backup fuse that is under the hood on the passenger side strut tower..
Old May 22, 2002 | 06:58 AM
94HybridEX's Avatar
Default Re: Fried a power wire, can I tap into a near by wire? (95CivicEX)
I did this, clock has power while car is on but doesn't retain time settings. Check under the hood, by the battery. It's a maroon fuse, says "7.5" on it. Change that **** and you're good to go!
Old May 22, 2002 | 07:05 AM
Zer0DazE's Avatar
Default Re: Fried a power wire, can I tap into a near by wire? (94HybridEx)
the constant for the clock and the radio are the same wire... just run a new wire with a fuse and split it...
i just had to do the same thing last month
Old May 22, 2002 | 07:39 AM
94HybridEX's Avatar
Default Re: Fried a power wire, can I tap into a near by wire? (Zer0DazE)
Why would you do that? Just replace the red 7.5a under the hood.
Old May 22, 2002 | 07:48 AM
4g4me's Avatar
well, troubleshooting without a meter is definitely not a good idea.(of corse I know this by your posts. With a meter you can check if you have power to thay wire or not, if the wire may still be shorted, if you have 12v switched, etc. I would recommend picking one of these up. And if you just WONT run a new wire from your battery(fused), then tap into your main ignition at the column.(fuse it) Just like an alarm.
redsled00
Audio / Security / Video
Apr 10, 2009 10:17 PM
FlaN.
Mar 3, 2004 08:34 AM
itsJDMyo
Nov 24, 2003 01:02 PM
Sirus
Oct 5, 2002 09:04 PM
