How much should a used 2000 SI prop valve cost?
Old Feb 28, 2007 | 10:20 PM
**DOHC HaTcH**'s Avatar
Default How much should a used 2000 SI prop valve cost?
Some guy locally is selling one for $40
good price? cause i have no idea
Old Feb 28, 2007 | 11:17 PM
Targa250R's Avatar
be professional
Default Re: How much should a used 2000 SI prop valve cost? (**DOHC HaTcH**)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by **DOHC HaTcH** &raquo;</TD></TR><TR><TD CLASS="quote">Some guy locally is selling one for $40
good price? cause i have no idea</TD></TR></TABLE>
Considering that it is the same valve found on all '96-00 hatchbacks (and a couple of other '96-00 models as well), you may be able to find it cheaper from a local junkyard.
Most used prop valves seem to go for $30-40 shipped.
Old Feb 28, 2007 | 11:53 PM
Timmay's Avatar
Default Re: How much should a used 2000 SI prop valve cost? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Most used prop valves seem to go for $30-40 shipped.</TD></TR></TABLE>
Si is different from any other 96-00
and 30-40 is about right.. i paid 35 shipped i think
Old Mar 1, 2007 | 12:31 AM
American.Graffiti's Avatar
Default Re: How much should a used 2000 SI prop valve cost? (Timmay)
Go to a u pull it if available.
Old Mar 1, 2007 | 04:34 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">Si is different from any other 96-00</TD></TR></TABLE>
No, you're wrong. Try again.
Check the part numbers. 46210-S04-902 is the part number of the USDM (non-ABS) EM1 proportioning valve. The same part number is found on all '96-00 3dr CX, 2dr and 3dr DX, and 2dr HX trims.
Old Mar 1, 2007 | 05:24 AM
pdiggitydogg's Avatar
Its the same one thats in all ek hatchbacks
check the part number
Old Mar 1, 2007 | 10:28 AM
Timmay's Avatar
Default Re: How much should a used 2000 SI prop valve cost? (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">
check the part number</TD></TR></TABLE>
i checked before i posted and what i got was different
why would a Si( rear disc) prop valve be the same as a non rear disc car?
edit: just looked it up again and looks like the EX shows a different part number but dx 3dr was the same.. also 4 door lx shows a diffferent part number
i would of thought that the SI is a 40/40 being it had rear disc
Modified by Timmay at 12:47 PM 3/1/2007
Old Mar 1, 2007 | 11:21 AM
Targa250R's Avatar
be professional
i would of thought that the SI is a 40/40 being it had rear disc</TD></TR></TABLE>
The 4040 (it's not marked "40/40"; this isn't an eye chart) is not used on all non-ABS cars with 7CLP13S rear calipers - only some.
Rear drums vs. discs are only half the story. There are 4 brakes on a car, not 2. The proportioning valve depends on both the fronts and the rears, not just the rears alone. The Si shares front brakes with the EX and not the CX/DX/HX/LX, so the proportioning needs with that particular front/rear combination - while not being the same as on DX 4dr, LX, or EX non-ABS - may be the same as the proportioning needs of the front/rear combo on the CX, DX 2dr/3dr, and HX. Hence the reason Honda equipped it the way they did.
OE brake proportioning valves (particularly the significance of the number codes) are still somewhat of a mystery to those of us doing the brake research. The best advice that I can give to anybody doing brake swaps is to use the proportioning valve from a car that has the closest possible OE brake setup to their new combo.
Modified by Targa250R at 3:34 PM 3/1/2007
Old Mar 1, 2007 | 11:34 AM
Timmay's Avatar
damn ya learn something new every day.. i got a SI one for my 4x114 swap.. being that i figured it was setup more for rear disc.. not sure if its better than my 97 lx stock one or now
Old Mar 1, 2007 | 11:46 AM
Syndacate's Avatar
I'd say 30-40 is fine.
Considering it's 90 dollars from honda.
Wouldn't pay more than 40 though.
Old Mar 1, 2007 | 12:43 PM
Targa250R's Avatar
be professional
Default Re: How much should a used 2000 SI prop valve cost? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">I'd say 30-40 is fine.
Considering it's 90 dollars from honda.</TD></TR></TABLE>
It's actually $111 retail.
Prices from online wholesalers don't always reflect reality - especially before you've factored in the shipping.
Historyg
Feb 19, 2008 05:01 PM
da6 sukkah
Jul 27, 2007 02:07 PM
JdMeF9SiR2
Mar 12, 2006 03:27 AM
oxSLEEPERxo
Aug 13, 2005 04:15 PM
CivHatchH22
Jun 5, 2003 11:41 AM
