What FPR do i need????
Im running a ej coupe
2.3l swap
gt40 turbo
100 shot, wet nos
255lph fuel pump
1000cc precision injectors
currently running a h22 FPR and im holding at 44psi consistant
I need to crank this up way higher to hold under boost and have enough gas for the wet kit
Plan on running 20psi range. Wondering what fpr should i use, im thinking the aem maybe, but a top psi rating according to there manuel of 57 psi wont be enough. unless there talking witha stock fuel pump ?????????????????????????!!!??????
Can someone give me input on this???
2.3l swap
gt40 turbo
100 shot, wet nos
255lph fuel pump
you are at the point you need an external. either the aeromotive which i use, or the sx, which lotsa people use. dturbocivic has said that on a setup where you need higher static pressures the sx is the way to go.
purpleh22
Jul 11, 2006 08:31 PM
