What FPR do i need????
Old Feb 28, 2007 | 09:37 PM
BOMBCRU's Avatar
Default What FPR do i need????
Im running a ej coupe
2.3l swap
gt40 turbo
100 shot, wet nos
255lph fuel pump
1000cc precision injectors
currently running a h22 FPR and im holding at 44psi consistant
I need to crank this up way higher to hold under boost and have enough gas for the wet kit
Plan on running 20psi range. Wondering what fpr should i use, im thinking the aem maybe, but a top psi rating according to there manuel of 57 psi wont be enough. unless there talking witha stock fuel pump ?????????????????????????!!!??????
Can someone give me input on this???
Old Feb 28, 2007 | 09:55 PM
tony413's Avatar
Default Re: What FPR do i need???? (BOMBCRU)
goto the aeromotive website best products and they give you enough info on whats right for you
Old Feb 28, 2007 | 11:09 PM
zexxbo's Avatar
Default Re: What FPR do i need???? (tony413)
aeromotive or sx (essex)
Old Mar 1, 2007 | 05:54 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: What FPR do i need???? (zeimbo)
you are at the point you need an external. either the aeromotive which i use, or the sx, which lotsa people use. dturbocivic has said that on a setup where you need higher static pressures the sx is the way to go.
Old Mar 1, 2007 | 10:03 PM
BOMBCRU's Avatar
sweet thanks for the info guys.
so far total investment is $1640 for everything including the cars, going for 10's under 2k
Dc4LsTeG
18
Mar 29, 2012 10:42 AM
purpleh22
Jul 11, 2006 08:31 PM
Squad1
Sep 23, 2005 03:16 PM
Mr.Death
Jun 22, 2005 01:12 PM
TeamDOHCside
Jan 8, 2004 07:04 PM
