idling problem...driving me nuts...
Old Feb 28, 2007 | 07:13 PM
tobe1424's Avatar
Default idling problem...driving me nuts...
well i have a 96 ek hb and for now i have my D series motor in there...
i have a idling issue and the first thing i looked at was the IAC but its rivitted on there so i cant really do anything....but CEL is not on...it was about 2 weeks ago and it went away....but ive cleans the tps and checked a couple of things and nothing yet has solved the issue...
NEED SOME HELP HERE AS WELL
Old Feb 28, 2007 | 07:28 PM
Turbo_y8's Avatar
Default Re: idling problem...driving me nuts... (tobe1424)
you have an idling issue. there are hundreds of issues it could be, enlighten us.
Old Feb 28, 2007 | 07:49 PM
tobe1424's Avatar
Default Re: idling problem...driving me nuts... (Turbo_y8)
lol thats true...just wrote that up their in a hurry....
when i turn on the car it idles ok....like around 1500 whens it hasnt been turned on the entire day...and when like 2 minutes pass it starts jumping up to 1500 rpm and back down to idle.... this happens consistantly....
Old Feb 28, 2007 | 08:41 PM
broketuner-Sol_Si's Avatar
check my thread on idling issues...sounds almost identical...turned out to be the FITV I'll try and find the link for you.
https://honda-tech.com/zerothread?id=1884376
Old Feb 28, 2007 | 09:31 PM
ridin98civic's Avatar
Default Re: idling problem...driving me nuts... (broketuner-Sol_Si)
no FITV on obd2 if i remember correctly
Old Feb 28, 2007 | 09:35 PM
Default Re: idling problem...driving me nuts... (ridin98civic)
my y8 had a similar idle issue and i just swapped out my iacv with one from a crv b20, seems to be working.
Old Feb 28, 2007 | 09:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">no FITV on obd2 if i remember correctly</TD></TR></TABLE>
didn't know that, cool learn something new everyday.
Old Mar 1, 2007 | 03:57 AM
tobe1424's Avatar
yea i guess when i have time im going to take ou the throttle body and clean or replace the IAC.
all civic or b series IAC'S are the same?
Old Mar 1, 2007 | 11:34 AM
no the one i used from the b20 just happened to be the same. i believe since you have a y7 its a 3 wire iacv
Old Mar 1, 2007 | 12:05 PM
Jakester9500's Avatar
is there anyway you could have gotten air in your antifreeze lines?
Old Mar 1, 2007 | 01:30 PM
tobe1424's Avatar
Default Re: (Jakester9500)
yea i just fisnished changing my radiator...and its been doing it for the past couple of days right after i finished installing it..
how can that affect it..i know B series motors if im not mistaken have a bleeder but not a D16y7
Old Mar 1, 2007 | 01:39 PM
Turbo_y8's Avatar
Default Re: (tobe1424)
idle it with your setting to the hottest and fan motor on high for like 15 mins
Turbo_y8's Avatar
Default Re: (Turbo_y8)
with the radiator cap off
Old Mar 1, 2007 | 01:41 PM
tobe1424's Avatar
sure fluid wont spill? and why does this occur...i mean ive flushed the fluid before and never done this...or should i just go ahead and clean the IACV?
Old Mar 1, 2007 | 01:42 PM
Turbo_y8's Avatar
could have got lucky with no air bubbles. hoes your heat functioning in the car?
Old Mar 1, 2007 | 01:47 PM
tobe1424's Avatar
I guess so...ok...dont want to get anoying...but like i said...how does air in the cooling system affect idling...
Old Mar 1, 2007 | 04:39 PM
tobe1424's Avatar
bump for help...cleaned out IACV and still does the problem...vaccum hoses looks fine....and no check engine light!
Old Mar 1, 2007 | 05:16 PM
Turbo_y8's Avatar
injector seal?
Old Mar 1, 2007 | 05:21 PM
D.Dappa's Avatar
try checking your TPS see if it reads out the right voltage at idle.
Old Mar 1, 2007 | 07:02 PM
tobe1424's Avatar
a friend of mine had the same problem with his teggy.... and it was the injector seal... but i dont smell any fuel or see black smoke....and again not CEL ...but i dont want to replace all the seals for no reason....
can they look new and still be bad?
Old Mar 1, 2007 | 07:05 PM
Turbo_y8's Avatar
i had surging idle with a bad injector seal. i wasnt throwing a code, didnt smell gas or any excess smoke.
Old Mar 1, 2007 | 07:16 PM
tobe1424's Avatar
cool...ill try that...so that would be the little tiny O ring at the end of it...or the injector seal that lays on the intake manifold
Old Mar 2, 2007 | 03:58 AM
tobe1424's Avatar
bump for bad idle...
Old Mar 2, 2007 | 09:10 AM
mhohenlohe's Avatar
O2 Sensor
FITV Cleaning (For integra, but should be about the same theory)
https://honda-tech.com/zerothread/1564019
Modified by mhohenlohe at 12:27 PM 3/2/2007
Old Mar 2, 2007 | 01:34 PM
tobe1424's Avatar
Default Re: (mhohenlohe)
NO CHECK ENGINE LIGHT.... ANYTHING THAT HAS TO DO WITH A SENSOR WOULD LIGHT UP THE CEL
