turbo??? i have a stock d16y7 non vtec how much psi can i boost and be safe???
Old Feb 28, 2007 | 06:47 PM
lunaticracer21's Avatar
Default turbo??? i have a stock d16y7 non vtec how much psi can i boost and be safe???
its a T25 turbo type-rs bov bootleg piping lol intercooler size 28-6-2.5 what do you guys think plz help i dont know about turbos thats why im asking
Old Feb 28, 2007 | 11:12 PM
yaaj1320's Avatar
Default Re: turbo??? i have a stock d16y7 non vtec how much psi can i boost and be safe??? (lunaticracer21)
i ran 15lbs with the 14b,dsm450cc inj., and chrome
Old Mar 1, 2007 | 03:22 PM
but im stock and dont have alot of money so i need the motor 2 last
Old Mar 1, 2007 | 03:34 PM
stockb18c's Avatar
10 psi should be fine i ran 13psi on mine and lasted two years...its a small turbo remember that
Old Mar 1, 2007 | 06:21 PM
THEDirtyDseriesWOOT's Avatar
i ran 15 on my y7 for a while till it overboosted to 20+ and boom .. its not how many psi its how much hp.. 220whp at the max on stock rods get it tuned on the dyno please for the love of god u cheap bastards
Old Mar 1, 2007 | 06:33 PM
AMLS4dr200whp's Avatar
Default Re: (stockb18c)
its all in the tuning but I wouldnt go past 12psi
Old Mar 1, 2007 | 09:40 PM
boosted_d16y7's Avatar
Default Re: (AMLS4dr200whp)
I ran that setup on all stock internals and a 12:1 Fmu at 10psi. After 10psi the fuel cut out. Just keep an eye on your oil and turbo seals or you will spin a bearing like I did.
Old Mar 2, 2007 | 11:01 AM
Thanks guyz I don't know what I would do if there's no honda tech lol
Old Mar 2, 2007 | 11:25 AM
HiProfile's Avatar
The 3 main problems d-series face are overloading the stock rods, too much timing (breaks ringlands), and over-reving (oil pump). The y7 also has a less-than-stellar crank, as the oil passages only go to one side of the main/rod surfaces. Not being cross-drilled is the main reason I think y7/y8 blocks spin bearings.
As long as you don't run crazy timing (1deg/psi is conservative) and don't rev past 7.5k, it should last a long time. Some guys run up to 250whp with stock D's, but they are usually in good condition and they maintain them very well.
Old Mar 2, 2007 | 11:39 AM
Schister66's Avatar
Man U FTW
Default Re: turbo??? i have a stock d16y7 non vtec how much psi can i boost and be safe??? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">The 3 main problems d-series face are overloading the stock rods, too much timing (breaks ringlands), and over-reving (oil pump). The y7 also has a less-than-stellar crank, as the oil passages only go to one side of the main/rod surfaces. Not being cross-drilled is the main reason I think y7/y8 blocks spin bearings.
As long as you don't run crazy timing (1deg/psi is conservative) and don't rev past 7.5k, it should last a long time. Some guys run up to 250whp with stock D's, but they are usually in good condition and they maintain them very well.</TD></TR></TABLE>
sounds like somone has some experience with D's.....good info!
Old Mar 2, 2007 | 04:23 PM
kool n/e 1 eles
Old Mar 4, 2007 | 02:25 PM
Default Re: turbo??? i have a stock d16y7 non vtec how much psi can i boost and be safe??? (Schister66)
all true except for the crank part.. just beacuase it has one passage isnt the reason it spins its the oil pump. i had a z6 crank because of the 2 oiling holes per journal in a Y8 block and it spun a bearing i found out that the stock z6 oil pump flows 30% more volume than the y7/y8 pumps
Old Mar 4, 2007 | 05:06 PM
so i need a z6 oil pump on my y7???
Old Mar 10, 2007 | 10:28 AM
N/E ONE???
RELLiK509
Sep 26, 2011 07:12 PM
ufakeit
Oct 2, 2009 10:19 AM
Drake_ep3
Sep 5, 2008 07:29 PM
superman336
Jan 31, 2007 10:34 AM
gregory
12
Jan 9, 2007 09:16 AM
