2006 Civic Sub and Amp install
Old Feb 28, 2007 | 05:59 PM
lsvtek's Avatar
Default 2006 Civic Sub and Amp install
Hi, I need some help. Is there a diagram anywhere that will tell me how to hook up the AMP wiring to the OEM deck on the civic? Thanks.
Old Feb 28, 2007 | 06:11 PM
fcm's Avatar
fcm
Old Fart
Default Re: 2006 Civic Sub and Amp install (LSintegra4)
What is the make and model of the amp?
Does it have speaker level inputs?
If not you will need a "LOC", [line output converter]... http://www.scosche.com/scosche...LOC80 something like that, it will be connected to the front or rear speaker outputs of the stock HU, giving you a set of RCA outputs, you can use HU acc. for amp control/trigger, amp power from batt. and ground amp to chassis/floor pan as close to amp as you can.. 94
Old Feb 28, 2007 | 06:14 PM
mrdeadman's Avatar
They let me pick
http://www.installdr.com/Harnesses/HA-Wiring.pdf
I don't know if this will work for an 06. I'll try to find more. This is for wiring an LOC to the factory deck.
Here's another:
https://honda-tech.com/zerothread?id=867142
Old Feb 28, 2007 | 06:51 PM
lsvtek's Avatar
Default Re: 2006 Civic Sub and Amp install (fcm)
thanks for the help, Yes, i believe i need the LOC thing. Because as far as im aware of, the OEM decks dont have outputs for RCA. I know how to do everything but install that LOC. Any help would be great thanks. Also on how to remove the deck.
Old Feb 28, 2007 | 07:00 PM
mrdeadman's Avatar
They let me pick
The LOC will come with instructions. There are four wires from the LOC that you need to splice. One for each rf, lf, rr, lr speakers. The diagram for doing this is in my post above.
VTECth1s
Audio / Security / Video
23
May 26, 2011 12:10 PM
Yun_Ej2
Apr 25, 2011 05:07 PM
supracrx
Jun 7, 2006 07:34 AM
ernie2409
13
Aug 22, 2005 07:49 AM
Mazzazx51
May 19, 2004 05:55 AM
