Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Installing a new shift knob?
Old Feb 28, 2007 | 05:43 PM
06SI=superior's Avatar
Default Installing a new shift ****?
How easy is it to take the stock shift **** off? I tried for a couple minutes before I went to class but it didn't want to move!
Old Feb 28, 2007 | 05:46 PM
haby red fg2's Avatar
there is a nut under the shift **** you have to loosen it i think it is a 13mm
Old Feb 28, 2007 | 05:56 PM
Rahxephon's Avatar
Default Re: Installing a new shift ****? (06SI=superior)
it's so easy even a caveman can do it
Old Feb 28, 2007 | 06:09 PM
Hellzcivic's Avatar
Under the Shift **** you will fine a nut mentioned above. Loosen the nut by turning it clockwise. Then unscrew the ****. If the **** you purchased came with a nut, check the thread pitch before you try to use it. I used my stock nut because the pitch was different on the nut I got with the Skunk 2 Titanium **** I got, which did not make sense since the pitch on the **** itself was correct. Screw the **** down as far as it will go, then back it off until the top emblem is straight. Then tighten the nut up while holding the **** so the emblem stays straight.
Btw, if you remove the nut, the nut goes on first, before you screw on the ****.
Old Mar 26, 2007 | 12:36 PM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Default Re: Installing a new shift ****? (Rahxephon)
ummm.
Old Mar 26, 2007 | 01:33 PM
TRE_'s Avatar
Default Re: Installing a new shift ****? (4F_HANS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4F_HANS &raquo;</TD></TR><TR><TD CLASS="quote">ummm.</TD></TR></TABLE>
Way to bring up a thread thats one month old and contribute absolutley nothing.
db8int3gra
Dec 11, 2008 06:52 AM
FNO1R
Nov 2, 2007 02:55 PM
Accord2NR
Oct 4, 2004 10:25 AM
andrewasf77
Nov 10, 2002 11:50 AM
civicboy95
May 6, 2002 10:48 AM
