Wiring Harness Question (cut harness)
Old Feb 28, 2007 | 05:08 PM
Bradstard's Avatar
Default Wiring Harness Question (cut harness)
I'm i the process of getting my theft recovery ITR put back together. I have not had a lot of time to spend on the car yet. The only major problem I've seen so far with this rebuild is the wiring harness under the hood. I am asking for some opinions here as to what I should do. Should I replace this part of the harness? Should I buy a JDM harness and cut that up and splice it in my existing wiring? Drop in a carbed 350 that dosen't need wiring?
Here are some pictures:
How the car currently looks sitting in the garage
Engine bay:
Cut harness on the passenger side
Cut harness on the driver's side
Interior
The ECU harness looks to be fine
On a side note, has anyone used this type of paint before?
I plan on painting the cage with this stuff
Let me know what you guys think I should do about the harness.
Old Feb 28, 2007 | 05:27 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Wiring Harness Question (Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">Drop in a carbed 350 that dosen't need wiring? </TD></TR></TABLE>
Old Feb 28, 2007 | 05:39 PM
OG undercover's Avatar
If you get the clips I'll do all the sodering
carbed 350 would be pretty cool tho
Old Feb 28, 2007 | 05:41 PM
Bradstard's Avatar
Default Re: Wiring Harness Question (GarageKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageKing &raquo;</TD></TR><TR><TD CLASS="quote">If you get the clips I'll do all the sodering
carbed 350 would be pretty cool tho </TD></TR></TABLE>
I might take you up on that. No 350 for me. I already bought a B18C5.
Old Feb 28, 2007 | 05:42 PM
importfan2's Avatar
I was in the same place u were about a year ago. i replaced the whole cabin harness and engine harness.. im at work right now so i cant look at ur pix.... just unplug it from the firewall and start wit a unmolested harness... and the harness dosent have to be from an itr just n e thing 96+.. my dumb *** at first bought a obd I which did no good
Old Feb 28, 2007 | 05:44 PM
Just leave me enough room to fit my hands in there and I'll be happy to help out.
Looks like we got time before it must be done, I call you when I'm coming.
Old Feb 28, 2007 | 05:45 PM
PrinceAli132's Avatar
Im not to sure how helpful this is, but if you do decide to repair your harness I could take pics of my harness for you. It is slightly hacked up but no where as near as bad as yours. I probably can take some pics this weekend for you to see if it helps. Also, I have the Helms electrical manual somewhere, which i can lend to you.
Ali
Old Feb 28, 2007 | 05:48 PM
Bradstard's Avatar
Default Re: Wiring Harness Question (importfan2)
I know it doesn't have to be a JDM harness but they are MUCH cheaper since you can't really use them in a USDM car. Are the harness plugs the same on the LS/RS/GSR as the ITR? I should be ok using any 96-99 since they are all OBDIIa. What about 00-01?
Old Mar 1, 2007 | 07:59 AM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">I know it doesn't have to be a JDM harness but they are MUCH cheaper since you can't really use them in a USDM car. Are the harness plugs the same on the LS/RS/GSR as the ITR? I should be ok using any 96-99 since they are all OBDIIa. What about 00-01?</TD></TR></TABLE>
yes they are, but you'll have to run the VTEC wires just like when you swap a c1-c5 into an LS. Also depending on what year LS harness, you may have to run another extra wire for the tach. Simple as can be though
the plugs from 94-2001 are exactly the same between the firewall harness and engine harness.
Old Mar 1, 2007 | 08:23 AM
walker111's Avatar
Default Re: Wiring Harness Question (Erik95LS)
I would solder them, this is cheap build on a budget, correct? I will peel back the tape and plastic and take some decen pics.... shouldnt be too hard. Hell, I'll even try to go to the junk yard and hack away a harness out of a obd2a teg.
Old Mar 1, 2007 | 09:04 AM
Dave_B's Avatar
You haven't finished that damn car yet???
Get on it!!!
I might have a 4 door GS-R harness for you if you need it. Just LMK.
Old Mar 1, 2007 | 09:16 AM
Bradstard's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">You haven't finished that damn car yet???
No, but it does look a little different:
When it got it home:
Now:
Old Mar 1, 2007 | 09:51 AM
walker111's Avatar
Default Re: Wiring Harness Question (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">I would solder them, this is cheap build on a budget, correct? I will peel back the tape and plastic and take some decen pics.... shouldnt be too hard. Hell, I'll even try to go to the junk yard and hack away a harness out of a obd2a teg. </TD></TR></TABLE>
After getting all the pictures..... You could go either way, besides a few extra plugs, I dont know what the difference between a gsr/ls and a ITR dash harness are..
Old Mar 1, 2007 | 09:54 AM
mr_gs-r's Avatar
soldering all that just seems iffy to me...could be an easy fix or a nightmare waiting to happen.
I may have the plugs you need i have a jdm itr harness but i cant remember if it still has the dash side of the harness connected to the plugs or not.
Old Mar 1, 2007 | 11:09 AM
Dave_B's Avatar
Brad, I'll take pics tonight and call you when I'm in front of the car.
Old Mar 1, 2007 | 11:11 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Brad, I'll take pics tonight and call you when I'm in front of the car.</TD></TR></TABLE>
You dont have a camera to take pics....
Old Mar 1, 2007 | 11:30 AM
Dave_B's Avatar
Default Re: (walker111)
You dont have a camera to take pics.... </TD></TR></TABLE>
LOL. Well I guess that then means you don't either...
Old Mar 1, 2007 | 11:35 AM
ITRnorway's Avatar
should be a easy fix if you could get a donor harness.
whats up with the electrical tape on the ecu connector wires?
Old Mar 1, 2007 | 11:39 AM
walker111's Avatar
LOL. Well I guess that then means you don't either... </TD></TR></TABLE>
Everyone has seen my pics....
Old Mar 1, 2007 | 11:42 AM
Dave_B's Avatar
Everyone has seen my pics.... </TD></TR></TABLE>
So... I don't share mine as much. I figure you guys don't want to see me and the lady going at it.
Old Mar 1, 2007 | 12:03 PM
walker111's Avatar
So... I don't share mine as much. I figure you guys don't want to see me and the lady going at it. </TD></TR></TABLE>
I'll look at your old lady going at it, as for you......midget **** is for the circus.
Old Mar 1, 2007 | 12:09 PM
Bradstard's Avatar
Default Re: (ITRnorway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRnorway &raquo;</TD></TR><TR><TD CLASS="quote">should be a easy fix if you could get a donor harness.
whats up with the electrical tape on the ecu connector wires?</TD></TR></TABLE>
Looks like it had a VAFC installed. Overall, it's all there. I'm glad they didn't snip those wires too.
Old Mar 1, 2007 | 12:10 PM
jzak1's Avatar
bradstard, the paint should be fine to use..good luck with the harness
Old Mar 1, 2007 | 01:08 PM
Hooch'n's Avatar
Default Re: (jzak1)
looks much cleaner then the project i am working on..... let me know about the paint...could use some of that ****
Old Mar 1, 2007 | 01:20 PM
Comp97GSR's Avatar
Default Re: (Hooch'n)
Brad, I was going to rewire the GSR a few months back. I would say find the plugs if at all possible. A complete main harness is not cheap (and you may not need the whole thing) as you know and a GSR harness is not exactly plug and play unfortunately.
I can not tell, any interior wires cut too?
