LED for Gauge Cluster?????
I want to change my gauge cluster bulbs in a 1996-2000 civic to LED. I found some LED at http://superlumination.com. But I dont know if they'll fit into the gauge cluster, because they're a little bit bigger than the regular bulb. Anyone with any experience with these LED light????
from http://superlumination.com:
#74 bulbs replace the following bulbs:17 18 37 70 73 79 85 86 2721
Introducing the Tri-Power 3 LED Bulb
The Widest, 3x Brightest and Best #74 Leds Ever Made!
Designed especially for gauges, and applications requiring a large uniform field of bright light*
Bulbs are 3/4" (20mm) x 3/8 (10mm)" diameter at widest point with T5mm base to fit standard #74 or #37 sockets.
Introducing the Tri-Power 4LED Bulb
The Widest, Brightest and Best Leds Ever Made!
Outfitted with 4 of the latest Super High-Flux low profile Leds*
Note: These are slightly larger than stock #24 bulbs.* Please measure your opening to make sure they will fit.*
#74 too small?.....#194 too big?.....This is your bulb:
#24 (T6-1/2, T2-1/4) bulbs are 5/8" (15mm) x 3/8 (8mm)" diameter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak »</TD></TR><TR><TD CLASS="quote">even tho it not that expensive.</TD></TR></TABLE>
47 dollars for some leds is pretty expensive.. I'll let you know how they are when/if they come in.
i put the sinlge led #74 bulb and its pretty dim. i got mine from this site, ordered on monday got them thursday.http://www.superbrightleds.com/
the led's will lokk 100x better tahn stock and put off great light. Plus with the multi-bulb application you don't have to mount extra bulbs tog et rid of hot spots or fill gaps.
Eran has a writeup for it in his sig.
Also the sticky at the top has a write-up too.
Also if you do a search on google you can find 2-3 on the first page from other forums.
i put the red ones in my jdm crx cluster and it was orangy and it really focused the light on certain spots instead of scattering the light evenly, I went back to stock asap.
mac_24_seven
Jan 10, 2014 01:23 PM
