Anyone know the torque specs for crower rod caps on a H22
Honda color codes their bearings. Green is the ''middle'' selection bearing and you'll most likely see these or yellows on dissassembled motors.
Crower's spec for the billets is 45ftlbs.
[QUOTE=PrecisionH23a]Honda color codes their bearings. Green is the ''middle'' selection bearing and you'll most likely see these or yellows on dissassembled motors.
Not sure if you understand... I bought the block built with crower rods already installed. What I need to know is if the bearings that they installed, which have green on the sides, are most likely oem honda bearings?
EDDIEONETIME
May 13, 2008 08:47 PM
