help me with my wiring: interior and engine bay stuff
car is a 92dx. first up, what should ground here??
[IMG]
[/IMG]
its under the drivers dash right by the hood pop/fuse panel. the harness i got with the car had so much other crap wired into it i lost track of where it should go.
next, behind the center console i had this extended plug that i cant figure out what it goes to.
[IMG]
[/IMG].
ok, when i give the car power (its got no motor or engine harness currently), the lights are constantly on and the fuel pump doesnt turn on.
what am i overlooking?
[IMG]
[/IMG]
[IMG]
[/IMG].
1st pic, nothing should be grounded to the main relay
2nd pic, there is a honda part# right on that pigtail, go to slhondaparts.com type in the part# and it will probably show you a picture of what it plugs into
(the part# has *****-SRO-1000) can't see the rest in your pic
also if the fuel pump isn't turning on try getting your main relay re soldered, search on HT and you will find how to do it
gl
gl
ok so nothing grounded over there, or just not in that exact spot? right now its not hooked up i had 2 wires but i cut them. i think they were stereo and gauge related anyhow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">no one knows about the ground??? i checked the helms it just tells me theres a ground not what its for</TD></TR></TABLE>
from the factory, nothing is grounded there.
and from the looks of it that is an aftermarket ground run from an aftermarket device. i dont think honda put yellow connectors on any grounds in these things, at least that i know of.
there are a couple factory grounds under the dash area, but i dont rightly remember where. its been a month or so since i been in that situation.
goodluck
goodluck
thank you. when i took out the harness that goes from the fuse panel to the cluster and console stuff, i think the only ground i had going to the car was the one on the steering column support kinda on the bottom right of thecluster in the back.
why would my lights stay on even if i have them turned off on the stalk
sohctodohc
41
Sep 9, 2010 04:06 PM
bakomack
Aug 3, 2009 09:19 AM
DaCRXboi
Dec 19, 2006 11:45 AM
