code p1259 (22) VTEC system malfunction???
Old Feb 28, 2007 | 12:29 PM
1clean_ Ej's Avatar
Default code p1259 (22) VTEC system malfunction???
what could it be? how do i fix it? also throwing p0113 (10) intake air temperature sensor circuit high input and the knock sensor is not hooked BC its broke off getting a new one this week but dont know whats goin on with VTEC????? help anyone?
I think the ecu is in limp mode from the (IAT) and the knock so if i fixed those two things would it fix the VTEC problem?
Old Feb 28, 2007 | 12:47 PM
SuzukaBlueAP2's Avatar
Default Re: code p1259 (22) VTEC system malfunction??? (1clean_ Ej)
Clogged screen under the VTEC solenoid?
Old Feb 28, 2007 | 01:08 PM
1clean_ Ej's Avatar
Default Re: code p1259 (SuzukaBlueAP2)
so that could cause it to throw a code?? I think we cleaned it before we put the motor in but im not sure.
Old Feb 28, 2007 | 01:20 PM
Default Re: code p1259 (1clean_ Ej)
I know it can cause issues, and possibly a code. It was just the first thing that came to mind and one of the simplest things to check.
Try it and reset the ECU. It might work.
Old Feb 28, 2007 | 01:45 PM
1clean_ Ej's Avatar
once i get all the sensor on ill try it and see what happens and get it scanned to see if its still throwing anymore codes
Old Feb 28, 2007 | 08:07 PM
1clean_ Ej's Avatar
could these be my quick fix? or what could it be?
ntoxicatedtigah
Jun 24, 2009 02:56 PM
salman
Nov 18, 2008 05:27 AM
dryhopsux13
Apr 8, 2005 06:02 AM
StupidSlowRSX
16
Oct 5, 2004 04:26 PM
leprechan117
May 13, 2003 07:01 PM
