Del sol clock/radio problem
I was wondering if anyone here may know the answer to my problem. I started my car today and the radio and the clock in my Del Sol would not turn on. I tryed changing the radio fuse but it didnt make a difference. Anybody have an idea as to what it could be?
I'm having a similar problem with my 95 del sol. I brought it to the dealership because I wanted to have a broken antenna replaced and a broken 6 cd changer removed, along with regular maintenance. They fiddled with the antenna but wanted to charge $300+ to replace it so I said to forget it. They did remove the cd changer, though. When they brought the car back to me, the clock was no longer working and the radio wanted a code. The guy said it's not a fuse because when you hit the R button the clock, you can still see it (though only barely and it doesn't 'take' changes). Also, I can enter the code into the radio and it will work again -- until I shut the car off. Every time I start the car, it wants the code again. I figure based on the 'so what' attitude I got from the service people when I pointed out these things weren't working (though they worked without problem prior to bringing it in), I'm going to have to fix this myself. But I know basically nothing about cars, especially anything electrical. Can anyone offer a total newbie some help on how to figure out the solution? That under the hood fuse sounds like it might be worth trying but I have NO idea where to find it and I don't have a manual for my car.
It was just the fuse. Good info here! I was gonna make a thread asking this same question. Saved me a lot of time.
Mine was just the fuse, too. I felt silly I didn't try it first. But I find it more aggravating that the Honda serviceman kept insisting that it couldn't be the fuse and that I'd need a new clock. Found out that particular dealership has a bad reputation. I'll never go back there again!
Yeah, I'm bumpin an old thread, but it just helped me out bigtIme. I pulled two clusters apart, swapped clocks, dimmers, changed bulbs.... ANYTHING to get the clock working. I had to wire the stereo differently to get it working (bought the car with no radio and clock not working, just been troubleshooting).
😅😅😅 i just literally changed my radio thinking it took a 💩...came here lookn for an answer and sho enuff i found it haha..my 7.5 fuse under the hood is blown!
delsizzle1
Feb 21, 2011 06:04 PM
russlan44
Jun 3, 2010 04:57 PM
marknir
Aug 10, 2009 12:49 PM
aleciakay2005
Jan 22, 2009 02:57 PM
