ls Vtec ecu question
Old Feb 28, 2007 | 09:37 AM
DarkTb16's Avatar
Default ls Vtec ecu question
I have a 93 hatch that im building an ls vtec for and was wondering which ecu i should run in it? Any suggestions?
Old Feb 28, 2007 | 09:42 AM
Archidictus's Avatar
Unceasing Measure
Default Re: ls Vtec ecu question (DarkTb16)
P72 with tuning.
Old Feb 28, 2007 | 10:00 AM
SkoundrelUSA's Avatar
cute little bastard
chipped P28 with at least a basemap of your setup
Old Feb 28, 2007 | 11:13 AM
MR.johnson's Avatar
Default Re: ls Vtec ecu question (SkoundrelUSA)
chipped p28 with tune for YOUR car.
Old Feb 28, 2007 | 11:49 AM
Relic1's Avatar
Default Re: ls Vtec ecu question (MR.johnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">chipped P28 with at least a basemap of your setup</TD></TR></TABLE>
good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson &raquo;</TD></TR><TR><TD CLASS="quote">chipped p28 with tune for YOUR car.</TD></TR></TABLE>
better
Old Feb 28, 2007 | 12:08 PM
doood's Avatar
been there done that
Default Re: ls Vtec ecu question (Relic1)
any chipped obd1 ecu will run it
Old Feb 28, 2007 | 12:59 PM
b18b1turbo's Avatar
chipped p28
Old Feb 28, 2007 | 09:08 PM
DarkTb16's Avatar
but does it matter if i use the p28 or the p72. will one run it better than the other??
Old Feb 28, 2007 | 09:46 PM
egsleepercivic's Avatar
Default Re: (DarkTb16)
P72 has the ability to control the IABs on a stock gsr intake manifold, so it depends which head u r using and if your using the stock manifold
Old Feb 28, 2007 | 09:59 PM
fmrprojects's Avatar
Default Re: (egsleepercivic)
get a p28 and chip it and get a base map so you can fire it up and drive it to the dyno and tune. or you can tow your car to the dyno and break it in on the dyno
Old Mar 1, 2007 | 10:45 AM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkTb16 &raquo;</TD></TR><TR><TD CLASS="quote">but does it matter if i use the p28 or the p72. will one run it better than the other??</TD></TR></TABLE>
p72 has recognizes a knock sensor. but an ls block doesnt have one anyway. so it doesnt matter which one you use. like i said earlier, any obd1 ecu will work.
DOHC Kid
May 27, 2008 04:47 PM
.I.Need.Money.
Aug 4, 2006 12:42 AM
EK9 ls vtec
Jul 15, 2006 08:28 PM
LL2009
Oct 5, 2005 11:24 AM
jdm'dc2sc61
Jul 2, 2005 12:23 PM
