strange Electrical/power steering problem
Old Feb 28, 2007 | 09:29 AM
monsterweights's Avatar
Default strange Electrical/power steering problem
OK, today I was idling, and the battery light came on. The battery is just a few months old, so i'm thinking alternator
I drive the car home eith all of the accesories off to save power, ad it make it home, with is more than 30 minutes away. When I get home, it's still acting like nothing is wrong, it starts up several more times, like it has a full charge. In fact, I can only tell something is wrong at all because of three things..
1st... the idiot light, never did go out...
2nd, there is a rattling coming from under the hood, but I can't tell exactly from where, but it's the belt side of the engine
3rd, and this is the strange thing.. My power steering doesn't work. I checked, and the belt is still there, so I have no idea why the electrical problem would cause my steering to go out.
It's a `1990 Civic LX with the 1.5 and a 5 speed
Can anybody help em with a starting place to look so I can fix it?
thanks
Mark
Old Feb 28, 2007 | 11:29 AM
Default Re: strange Electrical/power steering problem (monsterweights)
K, update,..
I went out and started the car, got a flash light to see if the belt was flopping...
It wasn't turning! Some how the entire pully isn't turning at all..
What could cause that, but it does explain why the power steering is not working.
Please help
Old Feb 28, 2007 | 01:33 PM
OK, so how can I drive a car 30 miles, but the pully isn't turning?
Modified by monsterweights at 3:06 PM 2/28/2007
Old Feb 28, 2007 | 03:48 PM
Crx Jimmy's Avatar
Default Re: (monsterweights)
I had that problem the alternator seized up. But it only took like 30 seconds after starting to make a cloud of rubber smoke before the belt burnt up. maybe your belt is loose so its not burning up, or maybe its not tensioned properly and its just loose so its not turning. The battery should have at least a 30 min reserve so you wouldn't notice anything yet.
Old Mar 1, 2007 | 03:38 AM
THe alternator s not siezed up, in fact I can move the belt quite easily by hand, THe pully is slightly wobbly, and it spins almost free too.
Any suggestions?
Old Mar 8, 2007 | 10:56 PM
4dr93civic's Avatar
check the codes!
https://honda-tech.com/zerothread/1901557
Old Mar 9, 2007 | 06:40 AM
snowseeker's Avatar
Default Re: strange Electrical/power steering problem (4dr93civic)
so your crank pulley isn't turning?
maverick01
Jun 4, 2016 03:16 AM
themp
Sep 30, 2008 02:57 AM
bennyDA
Sep 23, 2006 11:47 PM
GetCaughtDead
Sep 14, 2006 01:47 PM
Black '97 GSR
Nov 13, 2005 06:37 PM
