whats the deal??
Old Feb 28, 2007 | 09:03 AM
HbDrIvEr's Avatar
Default whats the deal??
so i just bought a carbon fiber spoon duckbill spoiler for my 93 hatch dx and a cd player from a local kid. the cd player isnt getting any power and wont turn on.....and the spoiler, i can t seem to bolt it down and open the hatch with out it hitting the roof....
i took off the stock spoiler with the 4 bolts (10mm) and unplugged the brake light and unscrewed the spray for the wiper...but when i put the new spoiler on, and open the hatch it doesnt open all the way and hits the roof.
heellpp
Old Feb 28, 2007 | 09:06 AM
da_dude's Avatar
I don't know what to think about the duckbill spoiler beside poor fitment. On the cd player check the wirings and check fuse.
Old Feb 28, 2007 | 09:24 AM
HbDrIvEr's Avatar
Default Re: (turb20_vtec)
alll the connections seem to be in...the stock harness from the car is plugged into the new harness to the deck and all the colors are matched up. and the black antenna goes right into the deck... i checks trhe fuse and it wasnt burnt out.. i cant figure out why the deck shows no power life....
Old Feb 28, 2007 | 09:26 AM
19992civichatch's Avatar
run the cd player off the battery to see if it is even any good
Old Feb 28, 2007 | 09:29 AM
HbDrIvEr's Avatar
Default Re: (19992civichatch)
? how?? do i drun it straight from the battery?
Old Feb 28, 2007 | 09:32 AM
jsu ttake the power from the headunit and the ground and touch it to the battery
does the headunit have a fuse in it?
Old Feb 28, 2007 | 09:48 AM
HbDrIvEr's Avatar
the deck has a fuse in it(10) and its not blown...
BY THE WAY, I GOT THE SPOILER TO WORK!!!!!! 2 OF THE BOLTS WERE KINDOF BENT SO I JUST GOT THEM IN THE HINDGE ALITTLE BIT AND THEN PUT THE NUTS ON. then i tightened them down slowly and lifted t he hatch up and down and nothing hits... so that problem is all clear..
except what should i do abut my spray for the wiper?? kink it off so it doesnt spray anymore??
Old Feb 28, 2007 | 10:01 AM
did u try the battery thing
Old Feb 28, 2007 | 10:38 AM
HbDrIvEr's Avatar
not yet....
Old Mar 10, 2007 | 08:33 AM
HbDrIvEr's Avatar
Default Re: (HbDrIvEr)
i figured out the problem. i had to connect the red and yellow wires tgether and for some reason it worked!
Old Mar 10, 2007 | 09:28 AM
95jeremie's Avatar
ok so your going to kill your battery
red=12 volt constant (right off the battery)
yellow=12 volt ign. (off the ignition switch)
by combining the two together your head unit won't turn off... thus killing your battery
Old Mar 10, 2007 | 10:11 AM
envee's Avatar
heh, nice call. if it doesn't turn on and your fuse isn't blown there is something wrong with the wiring. you having to splice two wires together would prove that it seems.
Old Mar 10, 2007 | 04:41 PM
have u checked ur backup fuse under ur hood, cd player wont work if its out
Old Mar 10, 2007 | 08:29 PM
HbDrIvEr's Avatar
hmmm well the batteryisnt dead and the deck isnt on when the car is off, but when i turn the car on and set the stations, and turn the car off...then turn it back on, the stations arnt set. soo hmm idk...this sucks.....
Old Mar 10, 2007 | 08:37 PM
hall97civic's Avatar
Default Re: (95jeremie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie &raquo;</TD></TR><TR><TD CLASS="quote">ok so your going to kill your battery
by combining the two together your head unit won't turn off... thus killing your battery</TD></TR></TABLE>
your backwards. yellow's constant, red is acc (switched 12 volts)
Old Mar 10, 2007 | 09:16 PM
92ehatch's Avatar
make sure the "backup" fuse under the hood isnt blown.
its a 7.5 amp fuse.
Old Mar 11, 2007 | 08:26 AM
HbDrIvEr's Avatar
Default Re: (92ehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">make sure the "backup" fuse under the hood isnt blown.
its a 7.5 amp fuse.</TD></TR></TABLE>
DAMN YOUR GOOD!!!! THAT WAS IT, THE FUSE WAS BLOWN SO I PUT A SPARE 7.5 IN THERE AND CONNECTED THE HARNESS WIRES FOR THE DECK CORRECTLY AND WHABAM!!!! IT WORKS LIKE THERE WAS NEVER A PROBLEM!!!
THANK YOU SO MUCH.
---DO CIVICS beep when the headlights are on when you turn the car off??? cause mine doesnt beep and i left them on, and batt. died. normally im used to hearing a reminder beeping noise...
Old Mar 11, 2007 | 09:04 AM
92ehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HbDrIvEr &raquo;</TD></TR><TR><TD CLASS="quote">DAMN YOUR GOOD!!!! THAT WAS IT, THE FUSE WAS BLOWN SO I PUT A SPARE 7.5 IN THERE AND CONNECTED THE HARNESS WIRES FOR THE DECK CORRECTLY AND WHABAM!!!! IT WORKS LIKE THERE WAS NEVER A PROBLEM!!!
THANK YOU SO MUCH.
---DO CIVICS beep when the headlights are on when you turn the car off??? cause mine doesnt beep and i left them on, and batt. died. normally im used to hearing a reminder beeping noise...</TD></TR></TABLE>
mine doesnt beep, its a 92 though, i dont know when they started adding beepers. they are supposed to beep when the keys are left in, but mine doesnt do that either (mine is broken)
Old Mar 11, 2007 | 10:18 AM
HbDrIvEr's Avatar
k, mines a 93 dx and it beeps when the key is in but not when headlights are on .....ill just have to remeber... lol
thanks again
Old Mar 11, 2007 | 12:30 PM
92ehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HbDrIvEr &raquo;</TD></TR><TR><TD CLASS="quote">k, mines a 93 dx and it beeps when the key is in but not when headlights are on .....ill just have to remeber... lol
thanks again</TD></TR></TABLE>
you can install a beeper/buzzer
look in the FAQ at thet op of the page, i believe thre is a write up on how to do it
have fun with your stereo
Danthemagicbum
Audio / Security / Video
May 22, 2010 07:02 AM
immrtaltchnq
Jul 18, 2009 10:01 PM
ineedmoney
Jun 3, 2004 06:28 PM
xXx Justin xXx
Nov 12, 2003 07:39 AM
AznInvasion
Jun 22, 2003 04:18 PM
