problem w/ swap
I'm having a check engine light on after doing a f20dohc swap w/ h23. The CEL comes on after the engine heats up to normal temp. Does anyone know why that comes on??? is it cause of my O2 sensor or a bad header??? i did throw in an aftermarket header. the oil sending sensor is not the original...the bolt on the h23 is bigger so i cut off the wire to re-wire to the f20....throws CEL on after normal temp has been reach.....any ideas???
daggers
daggers
