Throttle Bodies.......
Old Feb 28, 2007 | 02:52 AM
Nicaraguense13's Avatar
Default Throttle Bodies.......
I read the B/D series Interchangeable parts and it says that the Throttle bodies are interchangeable i seen a B20 TB on a B16 but when i put a D16y7 on a Ls nothing. Can a B16 or GSR fit my LS intake manifold with no problem????? thanks !! OO and does it matter if it OBD2 or OBD1 cuz the Intake Manifold is OBD2. THANKS
Old Feb 28, 2007 | 05:43 AM
Default Re: Throttle Bodies....... (Nicaraguense13)
bump!!!!!!!!!!!1
Old Feb 28, 2007 | 05:46 AM
Luserkid's Avatar
You dont want to use the y7 throttle body because it has a 3wire IAC that will screw everything up for you. It could still bolt on but i wouldnt use it. You could use any 92-01 throttle body but i recommend getting an integra as they are bigger then civic (minus 99-00 SI)
Old Feb 28, 2007 | 06:30 AM
elmo908's Avatar
I have another question regarding this issue, would a b18 throttle body hurt the performance of the b20 or is the difference in bore not that noticable. Wallace
Old Feb 28, 2007 | 06:50 AM
pdiggitydogg's Avatar
the b18 tb is the same one as on the b20...so no
Old Feb 28, 2007 | 09:38 AM
Default Re: (pdiggitydogg)
so i can use a GSR or LS tb???? or a 99-00 B16???
Old Feb 28, 2007 | 12:36 PM
MR.johnson's Avatar
Default Re: (Nicaraguense13)
ANY b-series TB will work.
VitaminB20
Jul 10, 2018 11:12 AM
want2na
Aug 12, 2014 06:14 AM
Mr.DC2TurBo
Mar 22, 2010 04:21 PM
Lambo123
Jul 12, 2009 06:29 AM
precisionelite
Apr 19, 2006 09:21 AM
