d series heads
Old Feb 27, 2007 | 11:09 PM
GsrTurboCRX88's Avatar
Default d series heads
I snaped my timing belt on my civic si and my valves are bent. Will any d series non vtec head work or do i have to use a d16a6 head. Basically i need to know if i can use a newer head and will my IM and exhaust manifold mount up correctly
Old Feb 27, 2007 | 11:41 PM
njn63's Avatar
Default Re: d series heads (GsrTurboCRX88)
all 88-00 sohc d-series head will physically bolt up. Pretty much any 16v non-vtec head (d15b7/d16y7/d15b2/d16a6) should work. I know for sure the d15b2 and a6 are the same head casting.
Intake manifold and Exhaust Manifold will be the same pattern and port arrangement.
Old Feb 28, 2007 | 04:11 AM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: d series heads (njn63)
Yeah, just find you a cheap DX head, and carry over your cam and get new si valve springs... A word of advice, use a head gasket for a 1995 Civic si. It's metal and clean up next time will be a snap. Good luck.
Old Feb 28, 2007 | 12:05 PM
Default Re: d series heads (h8tred)
thanks guys
Old Feb 28, 2007 | 12:09 PM
89efDUSTY's Avatar
i like your avatar
Old Feb 28, 2007 | 12:10 PM
ryan89crx's Avatar
all 88-95 DX/SI(non vtec) heads are the same
Old Feb 28, 2007 | 12:29 PM
orfus5's Avatar
Default Re: (ryan89crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">all 88-95 DX/SI(non vtec) heads are the same</TD></TR></TABLE>
Wrong,
88-91 si/dx are different casting/ design than the newer ones
Old Feb 28, 2007 | 01:03 PM
dr_latino999's Avatar
Default Re: (orfus5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orfus5 &raquo;</TD></TR><TR><TD CLASS="quote">
Wrong,
88-91 si/dx are different casting/ design than the newer ones</TD></TR></TABLE> I do believe the D15B7 shared the same casting as the D16A6, do you have any reference pictures of one of the later heads? I do have an A6 head on my shelf but no B7s.
Old Feb 28, 2007 | 01:10 PM
Patman's Avatar
If your looking to score a head PM me, i have one with 155k on it, was working fine when it was pulled.
Old Feb 28, 2007 | 01:15 PM
ryan89crx's Avatar
Wrong,
88-91 si/dx are different casting/ design than the newer ones</TD></TR></TABLE>i think you are wrong...
why does Majestic Honda list the heads as the same part # then? full rocker assembly and all......
1990 SI
http://www.hondaautomotivepart...+HEAD
1993 DX
http://www.hondaautomotivepart...DX%29
Old Feb 28, 2007 | 02:37 PM
daveb91's Avatar
If you dont have luck finding a A6 head I have an extra one. IM if needed.
pmptwst17
Jan 25, 2011 07:17 AM
CIVICSI12
Sep 12, 2006 08:10 PM
the4ork
Dec 12, 2005 06:16 AM
trustnoone7935
Jul 2, 2004 08:19 AM
Dancing is Forbidden
Jul 15, 2003 07:28 PM
