Bolt size for rear T bracket?
Looking for the thread pitch and size (length) of the bolt for the rear T bracket for a 95 civic ex. The bolt I need is the bolt that goes through the rear mount and from one side of the T bracket to the other. Also, the bolt directly in front of that one that bolts through the T bracket and in to the block. I have the two bolts on the bottom that bolt into the tranny just need the other two. I would have read through the Helms manual here on my cpu but I forgot that I just wiped it out and its going to take 30mins to download Adobe. TIA!
Okay, so Adobe finally downloaded and I have looked...It says that both bolts are 12 x 1.25. If I am looking to replace these bolts, how long do the replacement bolts need to be? Thanks again!
Did you loose the bolt or something? You can prob just pick up the exact bolt you need from the Honda dealership, but they will prob charge you around $10 for it.
I wouldnt say lost the bolts, I have misplaced them haha! Yeah I knew they would charge an arm and a leg for it. I need the car done by Friday night and this is the only thing holding me back. I was just going to go buy two bolts to replace them but I dont how long they need to be...
delsolnewkid
Mar 11, 2006 04:12 PM
