fs/ft montana green mk2 turbo GTI
300whp at 16 psi,will Handle 25psi
_____Engine
2.0L ABA bottom end(NEW)
1.8L 16v head w/3 angle valve grind(NEW)
Euro Nation custom intake manifold
Euro Nation custom turbo manifold
Euro Nation 3" down pipe
Euro Nation 2.5" charge pipes
Garrett T3/T04E 60 Trim w/Stage 3 .63 A/R exhaust, V-Band discharge(NEW)
TiAL 38mm external wastegate
TiAL 50mm blow off valve
ARP head studs
ARP rod bolts
8 x 25 front mount
3'' exhaust(NEW)
_____Drive Train
O2A cable shift transmission swap
Peloquin Limited Slip Differential
Spec Stage 4 clutch
lightened G60 flywheel
_____Fuel System
Megasquirt'n'spark
60lbs Seimen Deka injectors
_____Suspension/Wheels/Brakes
Weitec Coilovers
16" Konig Traffik (wheels)
Dunlop SP Sport FM901 (tires)
10.1" front brakes
8.9" rear disc brakes
make me an offer/ trades
Modified by -mk2turbo- at 8:37 PM 2/27/2007
_____Engine
ARP head studs
ARP rod bolts
8 x 25 front mount
3'' exhaust(NEW)
_____Drive Train
Spec Stage 4 clutch
_____Fuel System
Megasquirt'n'spark
Weitec Coilovers
10.1" front brakes
I've always wanted this car... lets work something out.
http://www.hondamarketplace.co...97306
