Stock H22A4 or Built D16Y8? Need you inputs!
Old Feb 27, 2007 | 02:08 PM
LudaChris's Avatar
Default Stock H22A4 or Built D16Y8? Need you inputs!
I have a 97 Civic EX with no motor, sitting in garage is the stock D16Y8 and rebuilt stock H22A4 with all the hardware for the swap; except the ECU which I'm not certain what to use, ODB1 or 2 and what wiring harness to use(I believe it's my stock EK wiring harness, I know I have to extend a couple wires, please correct me if I'm wrong or give me some guidance or link for reference.------- What will you do? My options are: Slap the stock H22, I know it will be a headache with the wiring or forge the D16 towards 11:1 comp ratio. Note that both options will be using wet nitrous, 100 shot for stock H22 and about 125 to 150 for the D16. Need your inputs, I'm indecisive!
Old Feb 27, 2007 | 06:59 PM
LSR 0NE's Avatar
Default Re: Stock H22A4 or Built D16Y8? Need you inputs! (LudaChris)
I would just throw the h22 in it, if you have everything for the swap why not?.If you decide to go with the h22 just get a p28 and chip it!!!.(now about the wiring there's lot of info in here just search!). But then again its your car do what you think its best and most important , your budget.
Old Feb 28, 2007 | 07:48 AM
gibsanez's Avatar
N/A you'll hit the limits of the D before the H. 600cc is a pretty big difference.
Old Feb 28, 2007 | 08:54 AM
98vtec's Avatar
moderator emeritus
Default Re: Stock H22A4 or Built D16Y8? Need you inputs! (gibsanez)
1) displacement
2) potential
Old Mar 1, 2007 | 01:32 AM
88ED8's Avatar
H duce duce
Old Mar 1, 2007 | 09:15 AM
beak's Avatar
H22... no brainer.
Old Mar 1, 2007 | 01:06 PM
alphajesse's Avatar
H22, Neptune RTP on a p28/p30/p72, Blacktrax will do an awesome job of stuffing everything in there.
I'd only keep the d if you were going to go turbo.
DeeJHonda95
Jan 23, 2014 11:14 AM
LudaChris
Feb 27, 2007 02:32 PM
mikegeezy
Mar 13, 2006 08:18 AM
