which side of head flange to use?
Old Feb 27, 2007 | 01:57 PM
hondaboy4life's Avatar
Default which side of head flange to use?
hey i have a tuner toys diy manifold, and i need to know which side of the head flange to weld teh pipes to... does anyone know? lets say the flat part of the flang is pointing down, and ur looking at it straight on. THe bottom holes in the corners are at different height. WHihc one should be on my left and right?
heres a pic of the kit
http://static.zoovy.com/img/tunertoys/-/L/lmk
Old Feb 27, 2007 | 02:05 PM
DaveF's Avatar
Default Re: which side of head flange to use? (hondaboy4life)
whichever way it fits onto the head...
Old Feb 27, 2007 | 03:35 PM
Default Re: which side of head flange to use? (dturbocivic)
oh forgot to add my car is buried deep in snow and winterized and it would be a huge pain right now to try to take off my header and see if this fits.
Old Feb 27, 2007 | 04:21 PM
DaveF's Avatar
Old Feb 27, 2007 | 05:04 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboy4life &raquo;</TD></TR><TR><TD CLASS="quote">oh forgot to add my car is buried deep in snow and winterized and it would be a huge pain right now to try to take off my header and see if this fits.</TD></TR></TABLE>
Not as much of a pain in the *** as it'll be when you finish the manifold and realize the flange is on backward
Old Feb 27, 2007 | 06:37 PM
Bailhatch's Avatar
timing belt side hole is low i think.
So you have never built a manifold before and you are just gonna weld some stuff together and hope the turbo and wastegate fit in your engine bay? I think you should wait for spring so you can fit it properly. All you are saving by doing it now is 2-3 hrs of welding, plus that gives you more time to practice welding.
Old Feb 27, 2007 | 07:05 PM
Default Re: which side of head flange to use? (Bailhatch)
well heres the deal. I got the kit for practically nothing. I am taking a welding course and am getting so bored of just practicing beads, and also am using up alot of materials in the shop so i thought i would try a project. I already welded an intake for a friend, and now want to try a manifold. Reason im asking which side to use and seeming to be lazy is cuz i wanted to maybe tack it together by next class which is wed. Today and yesterday i was sick, so i cant even go out and unbury my car/work on it etc. Tommorrow i have a feeling i will be even more sick. This is just a practice piece which i dont care if everything fits 100% or not, even tho im aiming for it to be functional
I guess sounding by peoples judgements nobody's 100% sure, so i will just wait it out i guess and keep welding random pieces of metal together at the shop
Old Feb 28, 2007 | 08:26 AM
CoreyR's Avatar
if its b series the higher hole is on the distributor side, if its for a d series it doesnt matter its symetrical.
92cxturbo
Welding / Fabrication
Apr 18, 2011 07:03 AM
meanEG
Feb 2, 2006 07:15 PM
BEEYOND
Jan 26, 2006 12:45 AM
philipwight
Mar 9, 2005 10:19 PM
Optiks.
Nov 27, 2003 12:29 PM
