Honda S2000 Honda S2000
S2k Hesitation
Old Feb 27, 2007 | 01:46 PM
cheese steak Nazi's Avatar
Default S2k Hesitation
in 2nd gear rolling through a parking lot at about 8-10 mph when i tried to give the car gas and it wouldnt go it just bogged down!!
then it snapped out of it, so i thought maybe it was nothing...so then about 15 mins later at a light when i get ready to take off in 1st gear again the car kinda gets stuck and doesnt want to go and the car starts bucking (yes i do know how to drive manual) ...
the car also when i start it i let in run for like 2-3 mins to let oil pressure build up, then when i give the car a little gas to rev it up (not to much rev , only about to 3-4k) when the revs fall back down they fall all the way to like 2-3 hundred rpms and the car wants to stall, then it picks its self back up...
so i want to know if anyone has any clue as to what this may be !! the car only has 11k on it, so naturally im worried
thanks ..sorry so long
Old Feb 27, 2007 | 02:35 PM
s2k4me's Avatar
Default Re: S2k Hesitation (Cheese Steak ****)
i was thinking timing for a second but it only has 11k
i would do like a quick run down check spark plugs for oil
check for leaks check trans.
speed sensor
well all sensors
then i would check wiring
but its under warranty from honda i would just have them check it out.
Old Feb 27, 2007 | 02:36 PM
LAS2K's Avatar
1. you should have been in first gear
2. search for "map whack"
3. celebrate because its no big deal and your problem is solved.
Old Feb 27, 2007 | 04:46 PM
thanks LAS2K...whats map whack ??
Old Feb 27, 2007 | 04:49 PM
LAS2K's Avatar
Default Re: (Cheese Steak ****)
recent change in weather?
here is your map whack info
http://www.s2ki.com/forums/ind...09708
Old Feb 27, 2007 | 06:57 PM
Arsenal's Avatar
Default Re: (LAS2K)
hmm, wonder if this would cure the low idle (almost searching idle when approaching a intersection) on our 06 with only 11k miles
4drint3gr4
Mar 8, 2017 04:53 PM
fraserboostedh22
Aug 3, 2009 07:22 AM
4drint3gr4
Oct 15, 2007 10:27 PM
MR. BAR
Apr 21, 2005 02:16 PM
xbn83
Jan 10, 2005 08:07 AM
