Sludge in Intake Manifold?
Old Feb 27, 2007 | 10:40 AM
TunerShark's Avatar
Default Sludge in Intake Manifold?
so i was looking in my intake manifold yesterday and i opened the throttle plate and put my finger in there and there was a good amount of sludge built up right after the plate and im sure it went all the through the damn manifold, the car has 119,XXX miles on it and im wondering if its normal and if i should clean it out?
thanks
Old Feb 27, 2007 | 11:00 AM
MR.johnson's Avatar
Default Re: Sludge in Intake Manifold? (TunerShark)
sea foam.
Old Feb 27, 2007 | 01:32 PM
excivicboy96's Avatar
i didnt check my manifold but my TB had some on it. Probably from the PCV system.
Old Feb 27, 2007 | 01:35 PM
Luserkid's Avatar
Default Re: Sludge in Intake Manifold? (excivicboy96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 &raquo;</TD></TR><TR><TD CLASS="quote"> Probably from the PCV system.</TD></TR></TABLE>
Yep, if your car is stock with the Stock PCV system, or aftermarket with the tube going to the intake then youll have this.
Old Feb 27, 2007 | 01:38 PM
Default Re: Sludge in Intake Manifold? (Luserkid)
Probably not necessary in a street car, but do oil catch cans catch all this extra sludge?
Old Feb 27, 2007 | 01:50 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 &raquo;</TD></TR><TR><TD CLASS="quote"> Probably not necessary in a street car, but do oil catch cans catch all this extra sludge?</TD></TR></TABLE>
that's their purpose. and you'll most likely need one when making more power than stock.
Old Feb 28, 2007 | 10:10 AM
TunerShark's Avatar
Default Re: Sludge in Intake Manifold? (doood)
so what do you guys suggest i do?, im gonna be boosting in a few weeks here, i thought about removing the manifold completely and just giving it a good cleaning.
Old Feb 28, 2007 | 10:30 AM
SiYouLater's Avatar
Anyone have ideas about cleaning the sludge? Will spraying brake cleaner in there be safe?
Old Feb 28, 2007 | 10:38 AM
Default Re: Sludge in Intake Manifold? (SiYouLater)
use carb cleaner
Old Feb 28, 2007 | 10:39 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerShark &raquo;</TD></TR><TR><TD CLASS="quote">so what do you guys suggest i do?, im gonna be boosting in a few weeks here, i thought about removing the manifold completely and just giving it a good cleaning.
???</TD></TR></TABLE>
What I usually do is just spray some Throttle Body cleaner in there and carefully wipe w/e I can reach with a rag. Or you can seafoam. But the sludge is pretty much normal so don't worry too much. If you want, disconnect the hose from the valve cover to the intake and just run a breather filter
Mashimaro's Avatar
go to your local parts store and buy a can of carb cleaner. pull the throttle plate open, start spraying and wiping and continue till clean.
you mite want to do this to your IACV while you're at it anyways.
and yes, a catch can would help a bit if you're curious.
RNbuilt
Nov 10, 2007 07:44 PM
civic_36
Jul 7, 2006 07:18 PM
idriveadelsol7
Dec 8, 2005 11:29 PM
gawath
Sep 8, 2005 07:12 AM
Garrett
Jul 20, 2003 11:44 AM
