Need wiring help ASAP PLZ.
Trying to wire a aftermarket window kit. I need help I need to get power to this thing and in the directions it says splice into ignition wire or wire big enough to handle a 25A fuse. So I tried doing the first option to what I thought was the ignition wire Yellow wire and it blew the fuse then I tried it on the Black with yellow stripe and it did the same thing. I NEED help, just need to power these up, I also tried going directly to the batt and blew the fuse as well any help would be appreciated guys... Car is a 97 Honda Civic DX. Look at page 5 #19 I dont get it whre to plug it up.http://electric-life.com/insta...c.pdf
It was one within the powe supply cable but I rechecked my wiring and I had one of the wires going from the actuator to the switch was touching my power supply cable so its all good now. thanks.
