hondabond or high temp gasket maker?
Old Feb 27, 2007 | 03:56 AM
Gfunk176's Avatar
Default hondabond or high temp gasket maker?
i'm trying to stop my oil pan from leaking. i have a moroso oil pan. i've replaced everything twice now and done it right. gasket, small amounts of hondabond (one time) and high temp gasket maker the other, torqued to spec, let gasket set. i still have some leaking around the gasket. any suggestions?
Old Feb 27, 2007 | 05:14 AM
AutoXsi2000's Avatar
Default Re: hondabond or high temp gasket maker? (Gfunk176)
Have you checked your rear main seal? I'm having the same problem and bought a genuine honda oil pan, retorqued everything in sequence according to helms and still get leaks. My guess is, it's coming from the rear main seal. I'll have to check mine once drop the transmission and replace the clutch/flywheel.
Old Feb 28, 2007 | 01:10 PM
Gfunk176's Avatar
Default Re: hondabond or high temp gasket maker? (AutoXsi2000)
hmm...don't think so....i see some oil on the front side of the block too.
Old Feb 28, 2007 | 02:54 PM
mmuller's Avatar
Mad Scientist
try taking out the metal stoppers on the oil pan gasket.
try hylomar also
Old Feb 28, 2007 | 04:00 PM
hondasarethebest's Avatar
What oil you using is the oil pressure to much and causing the seal to blow out??? I had that problem on mine...
Old Feb 28, 2007 | 05:51 PM
luciferi's Avatar
Default Re: hondabond or high temp gasket maker? (hondasarethebest)
Try Honda Ultraflange. that is what the k series use to seal the gasketless oil pan.
Old Mar 1, 2007 | 12:21 PM
BuddhaSiR's Avatar
Default Re: hondabond or high temp gasket maker? (luciferi)
what oil pan gasket you using? OEM or aftermarket? You might be deforming the gasket when you torque it down.
Old Mar 2, 2007 | 09:13 PM
Gfunk176's Avatar
Default Re: hondabond or high temp gasket maker? (BuddhaSiR)
i have stock honda oil pan gasket...i'm wondering if the holes in the gasket are messing things up cuz the moroso oil pan doesn't have the little bumps to fill the holes. do you guys know of any aftermarket gaskets that don't have the holes.
94 IntegraLS
May 7, 2013 11:42 AM
ZekeComa
Aug 31, 2012 12:29 PM
miro_gt
Jun 24, 2007 08:02 AM
blackdelslo
Jan 3, 2005 07:35 PM
James
May 11, 2004 01:38 PM
