94 Integra LS 4 door part out plus a little extra
Old Feb 26, 2007 | 11:25 PM
greasemonkee's Avatar
Default 94 Integra LS 4 door part out plus a little extra
OK GUYS LOWBALL ME! My only rule is that if I have to go to drop off a package, I have to make $10. I need to get this stuff out of here.
This is mostly out of an automatic.
If you need something and it’s not on the floor, let me know and I might be able to retrieve it from the car before I haul it out.
If it doesn’t have a price, make an offer.
Steering wheel
Center console
Glove box
All door panels
Hazard, cruise, def. switches
intermediate shaft
B18B valvecover
Lower flywheel cover
Charcoal canister
Steering universal joint
All window regulators
Steering column shaft
Under dash fuse box
Engine bay fuse box
Sections of harness – including ECU section
Dash – flawless except for the upper defroster trim is cracked
All brake calipers
Parking brake cables
Lower manifold pipe
GSR muffler
LS muffler
LS stock cat obd1
Wipers
Instrument cluster
Acura badges
Rear trailing arm assy with good bearings and struts
Tial 50mm BOV flange – steel
If it is electrical, I will test to verify it works before I ship.
Modified by greasemonkee at 5:44 PM 3/1/2007
Modified by greasemonkee at 11:53 AM 3/2/2007
Modified by greasemonkee at 1:13 AM 3/8/2007
Modified by greasemonkee at 1:23 AM 3/8/2007
Modified by greasemonkee at 2:14 PM 3/14/2007
Old Feb 27, 2007 | 10:13 AM
Default Re: 94 Integra LS 4 door part out plus a little extra (greasemonkee)
up top
Old Feb 27, 2007 | 01:56 PM
Jo3f1sh's Avatar
what kind of shape are the dash and vents in? I'd also need the glovebox...oh and the center/shifter console if it'll fit a 2dr...
Price shipped?
Old Feb 27, 2007 | 02:23 PM
Default Re: 94 Integra LS 4 door part out plus a little extra (Jo3f1sh)
I checked the console and they come up as the same part # for 2 and 4 door, but you will have to use your ring around the shifter boot.
I have the corner defrost vents and the passenger vent. I don't have the driver side.
The glovebox and the three vents and the center console, how about $40 shipped? All are in good condition.
Old Feb 27, 2007 | 06:27 PM
39th_shadow's Avatar
pmed
Old Feb 28, 2007 | 12:55 PM
Default Re: 94 Integra LS 4 door part out plus a little extra (39th_shadow)
top
Old Feb 28, 2007 | 01:25 PM
sickofitall1113's Avatar
any chance you have the stock air box assembly with the arm? i need it to pass inspection
Old Feb 28, 2007 | 01:53 PM
DC2Integrals's Avatar
i was wondering if you still have the driver side fender liner.
Old Feb 28, 2007 | 02:14 PM
Default Re: 94 Integra LS 4 door part out plus a little extra (DC2Integrals)
Sorry, have neither of the two.
Old Feb 28, 2007 | 02:39 PM
94gsr_teg's Avatar
Hey i need the front driver side abs sensor, if you have it pm with price shipped to 54403
Old Feb 28, 2007 | 03:35 PM
HTLuver's Avatar
IM'd.
Old Feb 28, 2007 | 04:37 PM
ShinsenTuner's Avatar
No Jodas
40 shipped for those tails?
Old Feb 28, 2007 | 08:16 PM
Default Re: (ShinsenTuner)
$45 for the tails. They are in good condition.
Old Mar 1, 2007 | 09:45 AM
Default Re: (greasemonkee)
up
Old Mar 2, 2007 | 07:53 AM
on top
Old Mar 3, 2007 | 02:59 PM
ttt
Old Mar 3, 2007 | 10:50 PM
mike9571's Avatar
Did you sell the center console?
Old Mar 4, 2007 | 12:01 AM
Default Re: 94 Integra LS 4 door part out plus a little extra (mike9571)
Not yet.
Old Mar 5, 2007 | 08:09 AM
ttt
Old Mar 6, 2007 | 05:59 PM
bumpoid. List is getting shorter, but still have some left.
Old Mar 7, 2007 | 09:29 PM
LOWBALL ME! Have to clear the floor out.
Old Mar 9, 2007 | 07:21 PM
jdmeg6drifter's Avatar
do u have the rear seats
Old Mar 9, 2007 | 07:32 PM
Default Re: (jdmeg6drifter)
I did, but they were like toast.
Old Mar 10, 2007 | 04:48 PM
Itzmy91Teg's Avatar
Hey man got a couple parts lookin to see if you got 'em.
Rear disc conversion (for eg)
all the sensors off the intake manifold and fuel rail
throttle body w/ all sensors.
Lemme know watcha got. Cash in hand.
Old Mar 10, 2007 | 09:25 PM
j spec's Avatar
Default Re: (Itzmy91Teg)
factory air box, intake tube, etc?
