motor mounts??
Old Feb 26, 2007 | 10:51 PM
Bevenue's Avatar
Default motor mounts??
Does anybody make aftermarket motor mounts for the crx that still has the d in it? I appreciate all responses.
Old Feb 27, 2007 | 12:00 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: motor mounts?? (Bevenue)
there are a couple places that make motor mount inserts. its kinda like a urethane gap filler that you can probably find on jegs.com, but a better and probably cheaper way is to fill your mounts with 3m window weld. if you search youll find lots of people doing it. window weld is kinda expensive, but in my opinion, its one of the best mods i did, and it sounds like it is cheaper and definitely more effective than the inserts.
Old Feb 27, 2007 | 05:05 AM
Creep's Avatar
Default Re: motor mounts?? (sanimalp)
Wasn't there an article a while back on making your own poly mounts.
Just an idea.
Old Feb 27, 2007 | 08:02 AM
BIGTUNA's Avatar
Default Re: motor mounts?? (Creep)
http://www.explicitspeedperfor....html
Old Feb 27, 2007 | 09:21 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: motor mounts?? (BIGTUNA)
for about $40 in window weld, you can fill all your mounts. a lot cheaper than the $275 kit, and just as effective.
the $275 mounts would be a lot cleaner though.. and take less time. it takes about 2 full days for the window weld to dry.
Old Feb 27, 2007 | 09:32 AM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">for about $40 in window weld, you can fill all your mounts. a lot cheaper than the $275 kit, and just as effective.
..except when you break a motor mount. Never done it myself but i've heard of it happening.
Old Feb 27, 2007 | 11:11 AM
ALLMOTORCRX20's Avatar
Try the prothane inserts. I've heard pretty good things about those.
Old Feb 27, 2007 | 08:07 PM
Bevenue's Avatar
well. i have poly inserts now, and they are great. i have no complaint at all for em. however, i trashed a front trans mount....literally tore the mount in half. dont ask me how cuz i have no clue. Iwas just looking for something cleaner than the stock ones. if anybody knows any companies that show love for the d-series let me know.
I may however fab some mounts of my own....
Old Feb 27, 2007 | 09:34 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: motor mounts?? (njn63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njn63 &raquo;</TD></TR><TR><TD CLASS="quote">..except when you break a motor mount. Never done it myself but i've heard of it happening.</TD></TR></TABLE>
could you define break? as in structural failure of the mount? degredation of the rubber filler? something other than that?
ive been running filled mounts for almost 2 years now, and there is no sign of weakness developing in the mounts. The only side effect of filling them that i have noticed are increased vibration in the car, which undoubtedly cause more stress on the mounts themselves, but i think you are underestimating the strength of the stock mounts. i do a lot of research before i make a modification to my car, and i never once came across any issue regarding filling your mounts and premature failure.. if you have links i would be happy to read them.
Old Mar 1, 2007 | 04:28 AM
Bevenue's Avatar
before work bump!
help me out here guys.
Old Mar 1, 2007 | 05:04 AM
fkguitar's Avatar
Default Re: (Bevenue)
I've actually seen what was like hasport style performance mounts for the D series. I'm looking for them right now.
Old Mar 1, 2007 | 05:08 AM
fkguitar's Avatar
Default Re: (fkguitar)
Alright I found some D series mounts made by Enjo at JCWhitney.com, only thing is they are listed for 94-97 del sol, but thats still a d16 so I hope that helps a little.
Heres the link:
http://www.jcwhitney.com/autop...10101
Old Mar 1, 2007 | 05:30 AM
ChickenH's Avatar
i did this too broke the strap where it hooks on the top around the rubber. Also broke the clutch rod. IT happened because the car is really low and hit the ground with the trans going in or out of a parking lot. good thing it was my roomates car and i replaced it before he came home.. mine is not so low and had a b so theres no mount there.
Old Mar 1, 2007 | 01:36 PM
Bevenue's Avatar
mine didnt hit anything tho but thats exactly what it did to the mount
Bump!
alx_90ef
20
May 30, 2014 06:31 AM
Rod.
Dec 31, 2005 07:05 AM
peacexisxfree
Oct 13, 2004 08:14 PM
6GACCORDH22
Sep 11, 2002 06:01 AM
