NEED HELP HX wheels rubbing against break caliper!!!!!
OK just got some HX wheels for my 93 civic ex coupe. Well when i went to put on the wheels on, the wheel was rubbing against the brake caliper WTF is going on here. The guy i got them from had them on a EG so why would it be a problem fitting on my EJ. Need help please. thanks!!
You got them from a guy who didn't have EX brakes. You need 5mm spacers or grind off a little of the caliper edge.
oh ok i see well ill go ahead and grind it down a lil, that wont make harm the caliper will it? or where can i find the spacer and will i need extended wheel studs?
I think 5mm spacer is safe enough that you don't have to run extended studs. Just grind a little bit where it's rubbing.
scbmx87
28
Oct 11, 2008 03:40 AM
Civic Hx-T
12
Aug 27, 2003 07:33 PM
