Wiring help needed ASAP.
Old Feb 26, 2007 | 07:47 PM
97Ej6's Avatar
Default Wiring help needed ASAP.
Trying to wire a aftermarket window kit. I need help I need to get power to this thing and in the directions it says splice into ignition wire or wire big enough to handle a 25A fuse. So I tried doing the first option to what I thought was the ignition wire Yellow wire and it blew the fuse then I tried it on the Black with yellow stripe and it did the same thing. I NEED help just need to power these up, I also tried going directly to the batt and blew the fuse as well any help would be appreciated guys... Car is a 97 Honda Civic DX. Look at page 5 #19 I dont get it whre to plug it up.http://electric-life.com/insta...c.pdf
Old Feb 26, 2007 | 08:56 PM
S2k Hybrid's Avatar
Default Re: Wiring help needed ASAP. (97Ej6)
Did you try posting this in the electrical section? I bet someone can help you there, good luck
Old Feb 26, 2007 | 09:05 PM
95gsrEG's Avatar
hope you find out the problem..check the electrical part.. like s2k said..
Old Feb 27, 2007 | 10:18 AM
97Ej6's Avatar
Default Re: (95gsrEG)
I rechecked my wiring and I had one of the wires going from the actuator to the switch was touching my power supply cable so its all good now. thanks. Hello power windows
97Ej6
Audio / Security / Video
Feb 27, 2007 10:17 AM
staticrex
Dec 8, 2004 11:46 AM
Acho
May 31, 2004 06:23 PM
michoui16
May 4, 2004 04:35 AM
importfan85
Dec 30, 2002 11:54 AM
