Driveshaft Play?
Old Feb 26, 2007 | 04:29 PM
Arsenal's Avatar
Default Driveshaft Play?
Sorry no pics.
But, regarding the drivers side CV Joint. My old one got a tear in the inner joint boot, so naturally replaced it.
I have perviously used Raxles on the passenger side and have had great results, so I ordered one for the drivers side.
It arrived and we installed it fine. So I lower the car and drive off, and notice that upon acceleration it pulls to the left. Hmm, so naturally I assumed it was an axle issue as that is usually the culprit.
So raise the car back up, and if you put your hand on the inner joint, where it goes into the interm. shaft it has play back and forth.
I know there is suppose to be general play if you push it from side to side alittle, but this was in and out about 1/4". Like you could feel it go in slightly, then out.
It hasn't slid out or anything.
Cliffnotes: Is the drivers side inner CV joint suppose to have about 1/4" play in and out of the intermed. shaft?
Thanks
Modified by Arsenal at 5:00 AM 2/27/2007
Old Feb 26, 2007 | 04:46 PM
Dave_B's Avatar
Ok, for clearification purposes...
Is this play between the 2 shafts like you could have the intermidiate in one hand, and half in the other and you can twist them separate ways 1/4" or you can push the axle farther into the trans or hub 1/4" ?
Old Feb 26, 2007 | 08:01 PM
Arsenal's Avatar
Default Re: (Dave_B)
I can push the axle further into the intermediate shaft a 1/4" then pull it back out 1/4".
No twisting involved.
Old Feb 27, 2007 | 12:08 PM
Arsenal's Avatar
Default Re: (Arsenal)
Do I really need to post some pics of some new wheels??
laloquera916
Nov 5, 2010 03:54 PM
saikou
Jul 1, 2007 06:22 PM
sony224422
Oct 2, 2006 09:23 PM
Philip
14
Dec 4, 2005 08:41 AM
dubbedcorde
10
Jan 6, 2005 04:16 AM
