H2D or H2B guys! need mount info!
Old Feb 26, 2007 | 04:21 PM
racerpat94's Avatar
Default H2D or H2B guys! need mount info!
im in the process of installing my H2D kit in my EJ1(same as EG chassis) and it requires a custom driverside engine mount. im assuming its a hybrid of the H-series lower, and the D/B-series Upper. does anyone have pictures of how they made it? or simply of the finished product? thanks in advance guys!
(btw typical H-series -> EG mounts will not work for this application)
Old Feb 26, 2007 | 04:46 PM
RC000E's Avatar
Default Re: H2D or H2B guys! need mount info! (racerpat94)
I'm doing an H2D setup in an EF. I am using the Bisimoto plate (obviously).... Basically just get everything positioned then use some cardboard to mock up the mount design. Have it utilize the stock two hole mount on the H block and just....make the mount.
Old Feb 27, 2007 | 08:46 AM
Bakeoff's Avatar
this should be in Hybrid, not welding and fab.
Old Feb 27, 2007 | 01:28 PM
racerpat94's Avatar
Default Re: (Bakeoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bakeoff &raquo;</TD></TR><TR><TD CLASS="quote">this should be in Hybrid, not welding and fab.</TD></TR></TABLE>
all i need is info on <U>fabrication</U> of the mount itself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">I'm doing an H2D setup in an EF. I am using the Bisimoto plate (obviously).... Basically just get everything positioned then use some cardboard to mock up the mount design. Have it utilize the stock two hole mount on the H block and just....make the mount.</TD></TR></TABLE>
im using the Bisi kit as well. with a g22(f22 block+h22 head). could you get a photo of your mount? what you are saying makes perfect sense, id just like to see your results. did you weld the added section yourself? thanks btw!
Old Feb 27, 2007 | 02:06 PM
DaveF's Avatar
Default Re: (racerpat94)
search posts by user Ranta18
stolen from http://www.rndauto.com
Old Feb 28, 2007 | 07:31 AM
racerpat94's Avatar
Default Re: (dturbocivic)
damn a fixed/solid mount?! pretty hardcore. i think he is doing the swap into an EK. ill check it out though. thanks
hondayute
Nov 13, 2007 08:47 PM
Trbospnkr
Feb 8, 2004 09:31 PM
Neldawg
Jan 13, 2004 08:53 PM
SpoonMe
16
Aug 26, 2003 08:53 AM
