LS turbo??
Old Feb 26, 2007 | 04:06 PM
AZ90DATEG's Avatar
Default LS turbo??
Well now that i have a new JDM fully rebuilt b18a1 , I want to start pieacing a turbo kit together for it. Im going to do it over 6-8 months , so im in no hurry , i want to do it right the first time , with quality products. Im not going to run that high of boost, i was thinking between 7-9 psi. Can i keep stock internals running boost that high reliabily? I was wonder if anyone on here could give me a list of everything im going to need to do this right, I was hoping to run something simple for fuel managment and not something to complicated that is going to require a lot of tuning. The whole reason i want to pieace one together is because i was hoping to do this for about 1500$, and run anywhere from 200-230whp safely, so if someone could point me in the right direction with a list and what i need to do this right , and safely , id appreciate it , thanks.
Old Feb 26, 2007 | 04:15 PM
blumpfish's Avatar
Default Re: LS turbo?? (AZ90DATEG)
200-230whp is definately safe on stock internals.
i would go with a t3/t4 turbo
im guessing its obd0? oi would use turbo edit, its free
you could prolly make more like 250-280whp with that turbo and 9psi .. still safely especially since its rebuilt
Old Feb 26, 2007 | 04:26 PM
AZ90DATEG's Avatar
i forgot to add this is on a 92 , so itll be obd1
Old Feb 26, 2007 | 04:56 PM
AZ90DATEG's Avatar
bumb for info , i searched LS turbo and it only came back with 17 results
Old Feb 26, 2007 | 04:58 PM
Preferio's Avatar
Default Re: (AZ90DATEG)
You could have added this with your other post. The one which I told you that your "JDM b18a1" is actually a USDM motor.
Old Feb 26, 2007 | 04:59 PM
Preferio's Avatar
Default Re: (PreFerio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZ90DATEG &raquo;</TD></TR><TR><TD CLASS="quote">bumb for info , i searched LS turbo and it only came back with 17 results</TD></TR></TABLE> Did you attempt to search in archived?
Old Feb 26, 2007 | 05:27 PM
AZ90DATEG's Avatar
no ill try it , i was hoping someone on here would know though without searching threw the archives.
Old Feb 26, 2007 | 09:08 PM
integra racr04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZ90DATEG &raquo;</TD></TR><TR><TD CLASS="quote">no ill try it , i was hoping someone on here would know though without searching threw the archives.</TD></TR></TABLE>
most people do know, but then again, most people search before makin a topic on something... lazy noob
Old Feb 26, 2007 | 09:14 PM
TigerIntegra's Avatar
Default Re: (integra racr04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra racr04 &raquo;</TD></TR><TR><TD CLASS="quote">
lazy noob</TD></TR></TABLE>
lmao
Old Feb 26, 2007 | 11:29 PM
IntegraGSR-Turbo's Avatar
Default Re: (TigerIntegra)
haha...what is with people if you dont have anything to add to his question...then dont type it
Old Feb 27, 2007 | 03:55 AM
Import_spoon's Avatar
Default Re: (IntegraGSR-Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraGSR-Turbo &raquo;</TD></TR><TR><TD CLASS="quote">haha...what is with people if you dont have anything to add to his question...then dont type it</TD></TR></TABLE>
It helps if you search. Don't waste time nor space in this forums. If you read the rules then you would understand. I can understand why you said that.
Old Feb 27, 2007 | 04:18 AM
Preferio's Avatar
Default Re: (Import_spoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraGSR-Turbo &raquo;</TD></TR><TR><TD CLASS="quote">haha...what is with people if you dont have anything to add to his question...then dont type it</TD></TR></TABLE> Isnt' that the coal calling the kettle black?
thalwr1
Feb 2, 2009 12:54 PM
XES
Oct 19, 2005 05:50 PM
redlseg
Aug 2, 2005 07:55 PM
Doostur
Oct 3, 2004 09:52 PM
B_1_8_hatch
Nov 24, 2003 06:06 AM
