GSR oil/water pump identification. Need a little help
Old Feb 26, 2007 | 04:06 PM
the4g4d's Avatar
Default GSR oil/water pump identification. Need a little help
Just bought and assembled LS-V. I don't know if the Oil and Water pump are LS or VTEC units. Are there any tell tell signs or numbers on the casings of the pumps that will tell me what motor they are from? Any info is a start. Thanks for checkin me out.
Old Feb 28, 2007 | 08:43 AM
WhiteNess's Avatar
Default Re: GSR oil/water pump identification. Need a little help (the4g4d)
There are 2 b series water pumps....19t = LS....and a 22t = "vtec". As far as the oil pump goes....I know there is a way to tell the difference but I'm not 100% sure what it is. Also if ur timing belt is an ls "p75" u know atleast ur water pump is an ls. Vtec water pumps require a gsr "p72" timing belt on ls-vtec setups.
Old Feb 28, 2007 | 10:38 AM
NJcoupe's Avatar
Default Re: GSR oil/water pump identification. Need a little help (WhiteNess)
all obd2 oil pumps are the same. if it has the bolt holes for the CKF sensor; you're good to go.
Old Mar 10, 2007 | 08:29 AM
JoePSI's Avatar
Default Re: GSR oil/water pump identification. Need a little help (idriveacoupe.)
Can OBDII oil pumps be installed on OBDI engines without issue?
Old Mar 10, 2007 | 09:49 AM
NJcoupe's Avatar
Default Re: GSR oil/water pump identification. Need a little help (JoePSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoePSI &raquo;</TD></TR><TR><TD CLASS="quote">Can OBDII oil pumps be installed on OBDI engines without issue?</TD></TR></TABLE>
PM'd
Old Mar 10, 2007 | 09:58 AM
JoePSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveacoupe. &raquo;</TD></TR><TR><TD CLASS="quote">
PM'd </TD></TR></TABLE>
Answered all my questioons. Thanks
Old Mar 11, 2007 | 07:51 PM
the4g4d's Avatar
where would the bolt holes be for the CKF? Thanks for all the help so far guys.
Dkahn18
Mar 17, 2009 05:47 PM
Midori Green
Feb 9, 2008 01:03 AM
bankhead83
Jun 9, 2005 05:41 PM
VWkila
Jan 29, 2003 02:09 PM
