obdII --> obdI = no A/C? Help!!!!
Old Feb 26, 2007 | 02:50 PM
jewjew bean's Avatar
Default obdII --> obdI = no A/C? Help!!!!
I have a 99 LS teg. I switched to OBDI and I'm using uberdata. I pressed the A/C button and it won't come on. Before I switched, I checked and the A/C was working.
What do I have to do to get this bad boy to work?
Old Feb 26, 2007 | 06:45 PM
jaggrieger30's Avatar
Default Re: obdII --> obdI = no A/C? Help!!!! (small arm)
The same thing happened to me also???
Old Feb 26, 2007 | 07:09 PM
rippinitup01's Avatar
it sounds like when you got the ecu programmed they did ac (cut-out) as they call it when u got the ecu programmed. some programs cut-out the ac so it dosen't activate..
most likely the problem you can get it put back in the program of the ecu if you take it back the people who programmed it
bus i have a chipped p28 and it is in my 2000 si which is converted to obd1 and my as still works
2camsaam
13
Oct 2, 2015 12:44 PM
psychobear
May 22, 2014 10:21 PM
chrisfromsrq
Aug 11, 2009 11:07 AM
BoostedH
Feb 19, 2008 01:41 PM
