obdII --> obdI = no A/C? Help!!!!
I have a 99 LS teg. I switched to OBDI and I'm using uberdata. I pressed the A/C button and it won't come on. Before I switched, I checked and the A/C was working.
What do I have to do to get this bad boy to work?
Re: obdII --> obdI = no A/C? Help!!!! (small arm)
it sounds like when you got the ecu programmed they did ac (cut-out) as they call it when u got the ecu programmed. some programs cut-out the ac so it dosen't activate..
most likely the problem you can get it put back in the program of the ecu if you take it back the people who programmed it
bus i have a chipped p28 and it is in my 2000 si which is converted to obd1 and my as still works
2camsaam
13
10-02-2015 12:44 PM
